Convert Used Oil to Gasoline: Jonathan's Quest
This discussion centers on converting used oils, specifically engine and food oils, into flammable liquids for use in gasoline engines. Jonathan seeks methods to generate electricity from waste oil and explores the potential of a GEET reactor. Participants emphasize that used engine oil cannot be separated into gasoline or diesel components and suggest burning it directly leads to pollution. They recommend recycling used oil for lubrication and highlight that burning used cooking oil in diesel engines is feasible, referencing successful experiments with heavy fuel diesel engines.
  • Understanding of GEET reactor technology
  • Knowledge of external combustion engines
  • Familiarity with oil recycling processes
  • Basic principles of steam generation and combustion
  • Research the operation and efficiency of GEET reactors
  • Learn about external combustion engine designs and applications
  • Investigate oil recycling methods and their environmental impacts
  • Explore the use of waste cooking oil in diesel engines and related modifications
This discussion is beneficial for experimental engineers, renewable energy enthusiasts, and anyone interested in alternative fuel sources and waste oil recycling techniques.
jonathangauci
l am trying to use used oil to gasoline engine l make geet reactor to vaporized petrol diesel but no success to oil how can l convert used engine oils and food oils to gas or flammable liqiuds thanks jonathan
l want to generate electricity from waste oil if someone can help
Think external combustion. Burning oil to make steam.
Steam runs your power plant.
The real advantage, is it will burn just about any fuel.
It is why all of our early heat engines were external combustion.
As to the best way to burn oil, look up some of the oil fired boilers.
If you are making steam anyway, you might also look at steam injection cooling.
thanks for reply but l want to change used oils to gas to run a gasoline engine l have 5 petrol engines in garage if you heat oils to flash point can l use that gas for cocker or engine intake thanks
l want to biuld something like wood gasifier but l want to use used oil to run small gasoline engine can someone help me thanks or where l can buy a system to change oils to gas
Engine oil is not "crude" oil, and can't be separated into components e.g. gasoline, diesel, etc. Burning the oil directly will cause a lot of smoke and pollution. It's best to recycle the oil through to allow it to be reprocessed for other lubrication applications.
I can see two problems with what you are trying to do; used engine oil is a complex mixture which will not vaporise at a constant temperature so you'll need a sophisticated process to vaporise all the components, also some of the mixture will probably give off some fairly noxious pollutants. You can burn used cooking oil in a diesel engine, see old episodes of Top Gear or Mythbusters.
thanks my friend did you ever listened the geet reactor of pantone is it a scam because he told me that work with used oil its plans is 300 $
ok l read about used oil in diesil engines but did old engines work thanks
ok thanks every one or can someone help me to make wood or plastic gasifire l want something simple just for experimental thanks
You can boil the oil and the vapors can be made to burn cleanly. But then you end up with a lot of crappy left over that does not boil off.
Many over the road trucks burn oil mixed with diesel fuel and meet all EPA requirements.
Diesel engines sold as "heavy fuel" will even burn roofing tar cleanly.
yes that's good pkruse what tempreture l want to boil the oil ? can u send me some simple picture thanks
I experimented with this more that 4 decades ago. Sorry, I have not kept any data from that. In small gas engines, I found that if I got them good and hot running on gasoline, then I could switch over to oil and they would run just fine, with no black smoke. Heavy fuel diesel engines, like those common on large ships do the same. They start up on #2 diesel, and switch to bunker fuel after everything is hot.
Go ahead and post your pictures. That should be interesting.
ok thanks my friends for help you heat gasoline engine and put oil to gasoline engine or you are saying for vapors and what type off oil thanks
sorry l mean do you heat gasoline engine and put oil in it or you put vapors and do you remember your experiment what type of oil u use food oil or engine oil thanks
9K
