Converting function to Quadratic form
scg4d
1. Hi everyone. I'm looking for help with converting this function to quadratic form.
2. The function is f(x1,x2)=(x2-x1)^4 + (12*x1*x2) - x1 + x2 - 3.
The quadratic form I need to convert to is: f(x)=(1/2)x'Qx - x'b + h
where x is a vector=[x1 x2]', '=transpose, Q and b are vectors, and h is the constant. Also, Q is symmetric and positive definite (Q=Q' > 0).
3. The trouble I'm running into is that f(x1,x2) is 4th order, and the examples I have convert only 2nd order functions to the f(x) quadratic objective format above.
I hit a wall when I expand the quadratic to:
-b1 x1 + 0.5 a x1^2 - b2 x2 + 0.5 b x1 x2 + 0.5 c x1 x2 + 0.5 d x2^2
where Q=[a, b; c, d] and b=[b1; b2] and try to figure out the variables.
In case your interested, I'm looking for this info to solve a steepest descent problem, where the varying ak value is ak=g(k)'g((k))/( g(k)'Qg(k) ) where g(k)=Qx(k) - b.
Thanks for your help!
Here's something that might be helpful, although it has been many years since I did anything with quadratic forms.
You have f(x1,x2)=(x2 - x1)4 + 12x1x2 - x1 + x2 - 3.
Let u = (x2 - x1)2, and let v = x1x2.
Then your function can be written as
u2 + u + 12v - 3
= u2 + u + 1/4 + 12 v - 13/4
= (u + 1/2)2 + 12v - 13/4.
This could be viewed as quadratic in u and v, but with a coefficient of 0 on the v2 term.
Hope this helps.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
