Converting nanometers to meters
  • Thread starter Thread starter iphone26
To convert a wavelength of 720 nanometers to meters, one must use the conversion factor that 1 meter equals 1 billion (10^9) nanometers. The correct conversion involves dividing the nanometer value by 1 billion, resulting in 720 nanometers being equal to 720 x 10^-9 meters, or 7.2 x 10^-7 meters. The initial confusion stemmed from incorrectly dividing by 1000 instead of using the proper exponent. Understanding that 1 nanometer equals 10^-9 meters is crucial for accurate conversions. Properly applying this knowledge ensures correct answers in similar problems.
iphone26
the wavelength of a laser is 720 nanometers. convert the wavelength to meters.
i am not sure of an equation that will help me.
this question was on a quiz i had recently and i got it wrong. i just divided by 1000 as a complete guess.
1 meter = 10^9 nanometers I believe
thank you! as i think about it now my teacher did remind me that always add 10^9 after the wavelength.
Its 10^-9 I believe.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
