Converting to polar double integrals
  • Thread starter Thread starter cos(e)
    Integrals Polar
The discussion revolves around converting a double integral from Cartesian to polar coordinates. The original integral involves the expression (x+y)/(x^2+y^2) and is defined over a specific region. Participants clarify that shifting the origin is valid but may complicate the integral's evaluation. The correct limits for theta should be from 0 to π, representing the upper half of a circle centered at (1,0). There are concerns regarding the integration process, particularly with undefined logarithmic terms when substituting limits.
cos(e)
we are given the intgral from 0 to 2( the integral from 0 to sqrt(1-(x-1)^2) of ((x+y)/(x^2+y^2))dydx, so convert to polar integral and solve
i got integral from 0 to pi/2(integral 0 to 2cos(theta) of (x+y)/r dr d(theta), and not sure if I am right and don't know how to procede. i let x=1+cos(theta) and y=sin(theta) and r^2=x^2+y^2. sorry bout the ugly format but i don't know how to write it out in maths form.
Thanks in advanced
Strictly speaking, you have shifted the coordinate system so the origin is at the old (1, 0). That perfectly valid but might violate instruction to just change to polar coordinates.
If x= 1+ cos(\theta) and y= sin(\theta) then \sqrt{1- (x-1)^2}= \sqrt{1- r^2cos^2(\theta)}= sin(\theta) so your equation becomes y= r sin(\theta)= sin(\theta) and r= 1, a circle about the origin with radius 1 (the graph in the original coordinates is, of course, a circle about (1, 0) with radius 1).
But the fact that y is equal to the positive square root means you are only getting the upper half of the circle. The integral is from \theta= 0 to \pi, not 2\pi. And, in polar coordinates, the "differential of area", dxdy, becomes rdrd\theta.
Your integrand is (x+y)/(x^2+ y^2)=
\int_{r=0}^1\int_{\theta= 0}^\pi (r cos(\theta)+ r sin(\theta))/r^2= (1/r)(cos(\theta)+ sin(\theta)) r dr\theta[/itex]
ok i see, i thought about moving the orgin but i thought that would change my values of (x+y)/(x^2+ y^2) when integrating and screw up my integral? So in general, can i move the origin and the function in the double integral (in this case (x+y)/(x^2+ y^2) ) will always fix itself?
okay i did your double integral of sin(theta) + cos(theta) drd(theta) and i got 2 yet the answers in the book have pi/2+1.
i tried letting x=1+rcos(theta) and y=rsin(theta), r^2=x^2+y^2, and i get the double integral of 1/r+cos(theta)+sin(theta), but when i antiderive with respect to r i get log|r|+... and when i sub in the terminals for r(0 and 1) i get log|0| which is undefined.
any help please?
Good question Cos(e).
Worked Solution attached as Word Document. Fingers Crossed the file opens.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 19 ·
