Coordinate Systems: 3D Angles Explained
Three primary 3D coordinate systems exist: Cartesian (three numbers), cylindrical (two numbers and one angle), and spherical (one number and two angles). The discussion explores the feasibility of a coordinate system based solely on three angles, noting the challenges in defining a point's location without distance measurements. It is suggested that using three initial points can create a unique coordinate system based on the angles formed with a plane containing those points. The Cartesian coordinates (1, 0, 0), (0, 1, 0), and (0, 0, 1) are highlighted as effective reference points. The conversation emphasizes the complexity of establishing a functional system based solely on angles.
Trave11er
Hi!
I see there are three 3D coordinate systems based on either 3 number (cartesian), 2 numbers and 1 angle (cylindrical) and 1 number and 2 angles (spherical). So can't there be a system based on 3 angles? Thank you.
Mathematics news on Phys.org
Seems to me you would have some troubles defining the location of a point in space with 3 angles and no distances. Play with it see if you can see why.
I have to disagree with Integral here.
Given three points initially, then the angles the lines from each of those points to point p make with the plane containing the three points are unique and will establish a coordinate system.
If you already have a Cartesian coordinate system then (1, 0, 0), (0, 1, 0), and (0, 0, 1) will work nicely.
Wow! That is very nice. Thank you a lot.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
