Solving Coplanar Forces: 8kN, 6kN & 3kN at 45°
  • Thread starter JollyJed
  • Tags
    Forces
In summary, solving coplanar forces at a 45° angle involves using the principles of vector addition to determine the resultant force. By breaking down the given forces of 8kN, 6kN, and 3kN into their horizontal and vertical components, and using trigonometric functions to find the magnitude and direction of each component, the resultant force can be calculated. This method allows for the determination of the net force acting on an object in a specific direction, and is a fundamental concept in solving problems involving multiple forces acting on a single object.
  • #36
JollyJed said:
0kN?
Yes. Now what are you left with?
  • #37
like that?
and left with the 16kN mate?
  • #38
No. Forces are vectors and so you have to put arrows on those lines to give a direction. Taking the two 5kN forces, we have already said that the resultant of those two is 0 (or the zero vector to be more accurate). But you still have a 16kN force acting straight down. So what do you get in the end?
  • #39
No to the picture or no to the 16kN left over?
what i was told at college was the vectors could go in any direction, and would always give the same result..
  • #40
The picture. You are right in that 16kN is all that is left.
If I understand you correctly, that is simply not true. If the 5kN forces were pointing in the same direction, their resultant would not be zero. Hence direction matters.
  • #41
Ahh yes i understand what you mean now mate! so if one of the 5kN forces was facing the opposite way to the other i would be right?
so when drawing it graphically would i draw it the same? and obviously 'measure' the 16kn line?
cheers for all the help mate!
  • #42
What I think you mean is that if you have a vector pointing in some direction, you can translate that vector anywhere in space, provided you maintain it's orientation. E.g a vector with it's tail at the origin and it's head at 2 units pointing along positive x axis. Clearly, that has a length of 2 units. Now exactly the same vector is given by a vector that has it's tail at, say, 5 units along +ve x from origin and it's head 7 units along +ve x from origin. The length is still 2 and the direction is unchanged. This is probably what you meant.
  • #43
No, because you added them head to head.
The resultant is simply a vertical line pointing in the -ve y direction with magnitude 16kN.
  • #44
that was the example i was given (at the bottom)
so why can't i use that here?
  • #45
Why can't you use what here?
  • #46
Move the vectors like a did in the previous pictures? I am pretty sure the arrows are just pointing to where the origin is, which they were in the example but i could still move them..
  • #47
I don't see any arrows on your picture, but provided you always add vectors head to tail, you will get the right answer.
Looking at the solution at the top of your photo, it looks like one 4KN force is pointing along +ve y, the other along +ve x. When you add these head to tail, you get that diagonal of length √{4)2+(4)2 at 45 degrees wrt positive x. Then this is added head to tail to the 3kN force.
  • #48
Yes which is how i worked out the answer for that, so how do you do 6? from what you have said i don't change it at all and 16kN will be the resultant.. but how do i do it mathmatically?
5kN + 5kN = 0kN meaning 16kN is the resultant?
  • #49
Yes, 16kN is the Resultant vector magnitude.
  • #50
I cracked it cheers lads, you make 3 lines of a rectangle with the 3 you are given and the resultant is the last line :) 16kn :D
