MHB Explaining Copper(2) Oxide Bonding & ECs
  • Thread starter Thread starter markosheehan
    Bonding
Copper(II) oxide bonding involves copper losing two electrons, resulting in an electron configuration of 2-8-17 for copper and 2-8 for oxygen after bonding. The discussion highlights that while atoms generally seek full outer shells for stability, exceptions exist, particularly with copper, which can form stable compounds in multiple oxidation states. Copper(II) oxide is noted to be more stable than copper(I) oxide, despite not achieving a full outer shell. The conversation also touches on the complexity of electron configurations and the existence of stable bonding scenarios that do not conform to the typical full shell rule. Understanding these exceptions is crucial for grasping the nuances of chemical bonding.
markosheehan
Could someone explain the bonding of copper(2) oxide to me? What are each element's EC before and after?
i understand the copper has a variable valency and in this case it looses 2 electrons to make the overall charge 0. however i don't understand the electron configurations. coppers EC before is 2,8,8,8,3. it looses 2 electrons so it goes to 2,8,8,8,1 this is not stable and this doesn't make sense to me.
Mathematics news on Phys.org
The abbreviation EC has quite a few meanings in chemistry, can you be more clear about it please.
Anyway, copper (II) is a bit of an exception from memory. Try searching for why Cu(II) is stable.
Hi markosheehan,
I'm assuming EC stands for Electron Configuration?
Before the bonding Copper has the configuration 2-8-18-1 (there are 18 electrons in the M valence shell) and Oxygen has 2-6.
After the bonding Copper has 2-8-17 and Oxygen has 2-8.
And indeed Copper doesn't have a 'nice' full shell.
There are some complicated answers out there about why that is, but long story short, in this particular case Copper(II) Oxide is more stable than Copper(I) Oxide.
thanks I like serena . that's what i was looking for.
i thought when bonding takes place atoms always want full outer shells? are there exceptions?
There are many exceptions. I remember back in my first year chemistry course, my professor criticized the textbook for providing incorrect explanations to these exceptions. Most of the time these explanations go much beyond the scope of general chemistry courses, so I wouldn't worry about them.
Yes, there are exceptions.
Most elements have a stable bonding with a full outer shell, but they typically also have alternative stable bondings.
For instance $CO$ and $CO_2$ are both stable, and $CO_2$ is the one where $C$ has a full outer shell.
Copper is apparently one of the exceptions where the bonding with a full outer shell ($Cu^+$) is less stable than other bondings ($Cu^{2+}$ and $Cu^{3+}$). Note that Copper also has a stable Copper(III) Oxide binding.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
