Correlation of Complex Random Variables
EngWiPy
Hi,
Why there is a half factor in the definition of the correlation of complex random variables, like:
\phi_{zz}(\tau)=\frac{1}{2}\mathbf{E}\left[z^*(t+\tau)z(t)\right]?
Thanks in advance
S_David said:
Hi,
Thanks in advance
I don't think that's true as a general rule. For the example you give, an autocorrelation, the general formula would be
\rho_{zz}(\tau)=\frac{\mathbf{E}\left[z^*(t+\tau)z(t)\right]}{\mathbf{E}\left[z^*(t)z(t)\right]}
I'm guessing that in your case, 1/2 is just the normalization factor 1/E[z*z], perhaps because the real and imaginary parts of z are independent with mean square 1.
does this general formula apply to the real-valued case, too?
Yes.
The general formula for a correlation is \frac{Cov(x,y)}{\sqrt{Var(x)Var(y)}}. In the case of an autocorrelation, x, and y are the same (except displaced in time, which doesn't affect the variance), so the denominator reduces to Var(x) = E[x^2].
pmsrw3 said:
Yes.
So, 0.5 is just a normalization factor. Ok thanks a lot.
Regards
Namaste & G'day Postulate: A strongly-knit team wins on average over a less knit one Fundamentals: - Two teams face off with 4 players each - A polo team consists of players that each have assigned to them a measure of their ability (called a "Handicap" - 10 is highest, -2 lowest) I attempted to measure close-knitness of a team in terms of standard deviation (SD) of handicaps of the players. Failure: It turns out that, more often than, a team with a higher SD wins. In my language, that...
Hi all, I've been a roulette player for more than 10 years (although I took time off here and there) and it's only now that I'm trying to understand the physics of the game. Basically my strategy in roulette is to divide the wheel roughly into two halves (let's call them A and B). My theory is that in roulette there will invariably be variance. In other words, if A comes up 5 times in a row, B will be due to come up soon. However I have been proven wrong many times, and I have seen some...
