Cos theta=pi/2 hint pi/2 is not an angle.
  • Thread starter Thread starter jrjack
    Angle Cos
The discussion centers on the equation cos(theta) = π/2, emphasizing that π/2 is not an angle. Participants clarify that if only real numbers are considered, there is no solution since the cosine function does not yield values outside the range of -1 to 1. When approximating π/2 as about 1.57, it reinforces that cos(theta) cannot equal this value. The conversation also touches on the potential for solutions using complex numbers, but notes that this is not applicable in the current context. Ultimately, the consensus is that there are no real solutions to the equation.
jrjack
cos theta=pi/2...hint pi/2 is not an angle.
\cos\theta=\frac{\pi}{2} HINT:The real number \frac{\pi}{2} is not an angle.
I tried 0=\cos^{-1} \frac{\pi}{2}, but that equals no solution.
And if \frac{\pi}{2} were an angle the answer would be 0.
Am I solving this correctly?
What is an approximate value for π/2 numerically?
\pi \approx 3.14 so \frac{\pi}{2}\approx 1.57
and since \cos\theta=1.57, then...\theta=no solution, because: \cos\theta= -1\leq\theta\geq1
Hi jrjack. Are you at all familiar with complex numbers?
I'm not sure, but NO SOLUTION is always one of the possible options.
Please explain further how to use complex numbers in this problem.
You might want to say no real solutions instead though.
Of course, No Real Solution. Since we are not dealing with imaginary numbers in this lesson, I think that is appropriate. Thanks.
Yes that was my point exactly. :)
If you are only dealing with real numbers there is no solution. If you are allowed to use complex numbers (real and imaginary) then there are solutions.
