Understanding Coset Decoding: Resources & Explanations
  • Thread starter Thread starter kirti.1127
    Resources
Coset decoding is a method used in coding theory to correct errors in transmitted messages. Understanding this concept may require reviewing resources that explain its mathematical foundations and applications. For further information, users are encouraged to consult textbooks or online resources, as specific references were not provided in the discussion. A suggestion was made to search for "coset decoding" online for additional insights. Engaging with the topic through research is essential for grasping the complexities of coset decoding.
kirti.1127
1. How does coset decoding works?
3. Please help me to understand the above topic and give a reference book or website link to the topic.
Hi and welcome to Physicsforums!
You probably will want to re-read this https://www.physicsforums.com/showthread.php?t=94381. We are pleased to assist and help you understand topics and problems in areas of math and science, if you show us that you have put some thought into your question.
Hint: If you cannot find anything in your textbook under coset or coset decoding. Try looking around on the web.
Don't know anything about it myself (Information theory isn't it?) but if you google on "coset decoding" you will find several links (including two to your post!).
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
