Cosine function & Modelling Tides
The discussion focuses on using the cosine function to model tidal data, specifically the equation y=acos(nx-b)+c. The user has calculated the amplitude as 1.805 and the period as approximately 12.29 hours, but is uncertain about the phase shift and vertical shift values. Clarifications are provided on the roles of amplitude, angular frequency, phase shift, and vertical shift in the cosine function. The user is seeking assistance in determining the correct phase shift value, which remains unresolved. Overall, the conversation emphasizes understanding the components of the cosine function in relation to tidal modeling.
flyinghigh
I'm having a bit of trouble working out the cosine function for the data I have on tide charts.
I need to put the data provided into the cosine function y=acos(nx-b)+c
Morning average high tide: 5.137 metres
Morning average low tide: 1.29 metres
Afternoon average high tide: 4.732 metres
Afternoon average low tide: 1.35
Average high tide: 4.93 metres
Average low tide: 1.32 metres
Average time between high tide: 12.18 hours
Average time between low tides: 12.15 hours
y=acos(nx-b)+c or y=Acos(Bx + C) + D
Through research I know that amplitude, a, will be (average high tide - average low tide) / 2
so amplitude = 1.805
Period,n or B, will be average time between high tides, so 12.29
Now, I know that these are correct, but I'm no quite sure why. Nor do I know what the phase shift, b or C, will be. I have a feeling that c or D will be (average high tide + average low tide) / 2 = 3.125, but once again don't know why..
Any help would be most appreciated!
flyinghigh
Okay so the basic equation for the cosine function, as you have correctly is
y = Acos(Bx + c) + D
Where A is the amplitude
B is called the angular frequency. It is the 2pi (period of the cosine function y = cos(x)) divided by T where T is the period of your function. T is just the distance of one "cycle".
x is your x.
c is your phase shift for x. This is because you see, the c is inside the entire cosine function, and this would add to your x. A positive phase shift means a phase **** to your left on the x-axis and a negative phase shift means a phase shift to your right on the x axis.
D is the phase shift on the y axis. Its just like another linear equation where the y intercept is c. However, for this function, just ignore the D first and graph it. After this, shift the function up or down by D on the y axis
If you don't understand anything from ^, let me know.
If my explanation wasn't sufficient, you might want to try:
http://www.zweigmedia.com/RealWorld/Calcsumm9.html
Thanks for the clarification physicsnoob93. So, taking what you said into account, the function would be
y=1.805cos(2\pi/5x-??)+3.125
Is that on the way to being correct? I'm just not sure what C should be...?
flyinghigh
Ok sorry but I'm not really looking at the values but what you have to do is compare the cosine function:
y = cos(x) and your function.
You have to compare how much the x changes between the cos(x) function and the your function. This is the phase shift in the x direction.
K thanks for the help so far. If anyone else can help that would be greatly appreciated!
flyinghigh
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 16 ·
9K
