Cosmological Constant and the Colapse of the Universe
NWH
I was wondering if someone would mind talking a little about why the cosmological constant was introduced and what it actually means for the universe to collapse according to Einstein's Universe. I was reading up on Wikiepdia (not the greatest source, I know) in the Static Universe entry and it got me interested. Although it didn't go into too much detial on why this actually happened and what it meant. Any input is appreciated...
The essential point (when Einstein introduced the cosmological constant) was that a static universe would be an unstable equilibrium. To avoid either a collapse or an expansion he put it in. Later on Hubble discovered that the universe is expanding and more recently it was discovered that the expansion is speeding up. To explain this speeding up, most cosmologists have put the idea of a cos. constant back. This whole area is still open to further analysis.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
