B Could someone verify how this simplifies?
  • B
  • Thread starter Thread starter TheGreatEscapegoat
TheGreatEscapegoat
I don't know why but I'm having this mental block where I can't see how this simplifies.
I have the expression $$ \frac{1}{2}(1+ \sqrt{5}) $$. Now, I substitute for x into the expression $$ \sqrt{x+1}. $$ to make $$ \sqrt{\frac{1}{2}(1+ \sqrt{5})+1}. $$
The result should be $$\frac{1}{2}( \sqrt{5}+1)$$.
However, when I simplify it, I obtain $$ \sqrt{\frac{1}{2}( \sqrt{5}+3)} $$ and for some reason I am not seeing how to simplify that into $$ \frac{1}{2}( \sqrt{5}+1). $$
Mathematics news on Phys.org
lurflurf said:
notice that
$$x^2=x+1$$
verify this
that is what makes the golden ratio a special number
https://en.wikipedia.org/wiki/Golden_ratio
I don't see how that proves the simplification. If you don't know how to prove it that's fine I have nothing against you for it, and this isn't meant to be insulting, it's just very commonly held that it is rude to interject random comments for your own personal sake that don't actually address the topic.
It would be astounding if your COULD see it since it is not true
EDIT: HM ... seems I was mistaken
Likes jedishrfu
I thought it was wrong too, so I checked it with my calculator. Seems it is true, but I'm not seeing the algebra to make it true yet...
Yep. Me too.
Ha. Got it. It does simplify. I think lurflurf knew that all along :smile:
That's a fine conjecture, but you're missing proof, so for all I know you are wrong. Remember that the goal is to prove the simplification, not that it is a fixed point of $$ f(x) = \sqrt{x+1}$$
You may consider it to be so if you wish. lurflurf gave you the only hint you need
Again, that comment doesn't mean anything without proof. Furthermore, it is rude and counter-productive of you to assume you have the right to arbitrarily dictate what others need and don't need, you only determine what you need.
Again, that comment does mean anything without proof. Furthermore, you don't determine what others need and don't need, you only determine what you need.
I think you misunderstand the methodology of PF. We don't give answers, we help people figure out how to GET the answer. You've been given a sufficient clue. Ignore it if you so choose.
Likes berkeman
Thread closed temporarily for Moderation...
You can verify that they are equivalent by squaring both values.
The first gives 1/2 ( sqrt 5 + 3 )
And the second gives you 1/4 ( sqrt 5 + 1 ) * ( sqrt 5 + 1 )
Which becomes 1/4 ( 5 + 2*sqrt5 + 1 ) which becomes 1/4 ( 6 + 2*sqrt5)
Which reduces to 2/4 ( sqrt5 + 3 ) or more simply 1/2 ( sqrt 5 + 3 )
So they are indeed equal.
By reversing the verification you could derive the first expression from the second.
Likes berkeman
Since this is your (@TheGreatEscapegoat) problem, the burden of proof is on you, not us.
@phinds is correct in what he says about our principles here at PF.
Likes Vanadium 50, Doc Al and berkeman
After a long PM conversation, the OP has left the building. Thank you to everyone who tried to help him in this thread. Interesting links, BTW. :smile:
Likes jedishrfu and StoneTemplePython
