Could the reason why I can't select any kernels in VS Code be this error?
  • Thread starter Thread starter arhzz
7 replies · 5K views
arhzz
I am trying to run an .ipynb file and have installed Miniconda as well as created an environment as such
-conda create -n <env_name> python=3.7 ipykernel jupyter
I am assuming this is successful as I can activate this environment via the anaconda prompt and following command
-conda activate <env_name>
Then I downloaded and installed VS code and I am trying to edit an .ipynb file. I want to select a kernel, via VS Code but when I press the button on the upper right corner I am greeted with the message that I need to install Python and Jupyter extensions. As soon as I do that the following error shows up
"Extension activation failed run the 'Developer: Toggle Developer Tools' command for more information
Source: Jupyter (Extension)"
and I am not able to select any kernel.Additionaly,when I try running any Jupyter related commands such as
"Jupyter: Create Interactive Window"
I get error messages of the following type:
Command 'Jupyter: Create Interactive Window' resulted in an error (command 'jupyter.createnewinteractive' not found)
This error is common as far as I know and has been discussed here at StackOverflow. See following link Extension activation failed, run the 'Developer: Toggle Developer Tools' command for more information
Now I have tried the solution that was suggested on this question and it did not work. I tried installing prior versions of jupyter as well as tried completely deleting the extensions from the extensions folder. My last resort was reinstalling VS code altogether but that either did not resolve the issue.
So my question is could this be the cause of me not being able to select the kernel? If so how do I resolve this issue.
Many thanks!
What do you mean without the environment switch? Could you elaborate more.
On a side note I am now certain it is a VS code issue since I tried doing it the oldschool way and just opened a juptyer notebook and it worked just fine.
I misread what you were doing.
The suggestions I saw were:
1) Make sure that after switching to your new environment, you can run the Python command
//// which python
//// python --version
On my macOS, there is no Python; instead you call it up via python3.
2) Add Jupyter kernel for notebooks:
//// python -m pip install ipykernel
//// python -m ipykernel install --user --name xyz --display-name "Python (xyz)"
3) After switching to your new environment, when starting up VS Code, do it via the 'code' command to be sure it's got the same environment.
//// code .
4) You may need to initialize conda in your .zshrc (or .bashrc...):
//// conda init zsh // (or whatever shell you're using: bash, sh, csh, ksh...
$$ which python
$$ python --version
$$ python -m pip install ipykernel
$$ python -m ipykernel install --user --name xyz --display-name "Python (xyz)"
$$ code .
$$ conda init zsh // (or whatever shell you're using: bash, sh, csh, ksh...
Ah I see, already did that. unfortunately did not help. Guess I am going to stick with the oldschool way
Some comments recommended manually pointing VS Code to the Python executable via its configuration settings.
Reply
Okay so just to get back to everyone. I fixed it; it turns out when opening the file in VScode you need to go explicitly to the file with "Open File" and search for your .ipynb. Than after opening it that way the kernel shows up and it works fine.
Thanks everyone!
Reply
You are knighted as a true Jedi hacker of the highest esteem in the realm of software engineering and beyond.
These types of issues plague developers and end users all the time and it takes perseverance to find a solution or just a workaround.
Sadly, sometimes you can't find an online solution because so few bother to go back and explain what caused their issue and how they fixed it.
On another note:
Sometimes, being honest about what happened can have downsides especially at work. Some superficial bosses interpret your honesty and perseverance as weakness and a waste of time which over time leads to perceived poor performance ratings.
Look for the boss who appreciates your hard work and perseverance in the face of an insurmountable problem and rewards you for your efforts.
Thanks for sharing your solution.
May the Force be with you,
Jedi
Reply
