Coulomb's Law and spheres Problem
The discussion revolves around maximizing the electrostatic force between two charged spheres by transferring a portion of charge. The equation for the force is derived from Coulomb's Law, leading to the expression k(Q-q)q/r^2. The user initially struggles with taking the derivative and mistakenly factors before differentiating, resulting in confusion. After correcting their approach, they confirm that factoring can be done either before or after differentiation without affecting the outcome. The key takeaway is understanding the differentiation process and its implications for solving problems involving electrostatic forces.
frankfjf
Of the charge Q initially on a tiny sphere, a portion q is to be transferred to a second, nearby sphere. Both spheres can be treated as particles. For what value of q/Q will the electrostatic force between the two spheres be maximized?
(k)(q1q2)/r^2
I posted a similar problem concerning an electric field some time ago, and am attempting to use the same solution, that is, taking the derivative of the equation I end up with, but the derivative ends up being zero for me. I end up with:
k(Q-q)q / r^2
And then after factoring out k/r^2, I'm left with just (Q-q)q. I tried doing a derivation using the product rule, but I just end up with zero. When I try to derive this, I get:
1 * (1-1) + (Q-q) which just leaves me with Q - q, which is not the answer. What am I doing wrong?
You differentiated the equation with respect to...?
Ah nevermind, upon multiplying the q back into the (Q-q) and then deriving, I get the correct answer. However, can it be said as a rule of thumb that you should factor AFTER taking the derivative, or are there situations where you should factor beforehand?
Basically I used df/dq.
There's no difference between: \frac{d}{dq}\left(q(Q-q)\right) and \frac{d}{dq}\left(qQ-q^2\right), and this holds true no matter what kind of functions are in the product. (They should be continuous of course.)
