Coulomb's Low And Dirac Delta Functio
To prove Coulomb's law for a single point charge using the Dirac delta function, one must understand the charge density for a point charge, which is represented by the Dirac delta function. The integral form of Coulomb's law involves integrating the volume charge density over space, where the charge density for a point charge can be expressed as ρ(ŕ) = qδ(ŕ - ŕ₀). Familiarity with the properties of the Dirac delta function is essential, as it simplifies the integration process by effectively "picking out" the value at the point charge's location. It is recommended to review resources on the Dirac delta function to grasp its application in this context. Mastering these concepts will facilitate the proof of Coulomb's law.
life engineer
I want to prove coulomb's low for a single charge point from the general form of coulomb's low:
E→=1/(4∏€) ∫∫∫ ρv(ŕ) * (r→- ŕ→)/│(r→- ŕ→)│^3 dŕ
using Dirac Delta function
where r→ is the field point vector
ŕ→ is the source point vector
ρv(ŕ) is the volume charge density
I really don't know how to do it . I tried a lot but couldn't do it so can u help me please as soon as possible.Just guide me how to do it.
Hey guys I can use a little help here. Just give me a hint.I really really need ur help
The equation looks messed up (try LaTeX), but I guess you mean:
\vec E(\vec r)=\frac{1}{4\pi \epsilon_0}\int_V \frac{\rho(\vec r')}{|\vec r-\vec r'|^3}(\vec r-\vec r')dV'
Show what you have done so far. Ofcourse, you should know what the charge density of a point particle looks like.
yes ur guess is right the equation u wrote is the one I meant . yet I didnt reach any thing that make sense. I guess because I don't know the charge density for the point charge and because I don't know a lot about dirac delta function. I know it converts continuous functions into discreete ones Ithink this is the main idea of the solution but yet I don't know how Can u help me please?
Ofcourse, you should read up on what the dirac delta function is before using it to solve anything. I`m sure there's a discussion about it in your book.
http://planetmath.org/encyclopedia/DiracDeltaFunction.html
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
