Coulumb's Law and force between charge
  • Thread starter Thread starter thrills4ever
    Charge Force Law
The problem involves a point charge +Q experiencing electrostatic forces due to another charge -10Q, while being held in equilibrium by a tension in a string. The context includes the gravitational force acting on the charge and the need to analyze the system using Coulomb's Law and free body diagrams.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss breaking down forces into components using free body diagrams. There is an attempt to relate the electrostatic force to the gravitational force and tension in the string. Questions arise regarding the values of charges and the application of Coulomb's Law.
Some participants have provided guidance on resolving forces and using free body diagrams. There is an acknowledgment of the need to find the electrostatic force before determining the tension and charge values. Multiple interpretations of the problem setup are being explored.
Participants note the challenge of determining the value of charge Q, which is essential for solving the problem. The setup involves specific distances and angles that may affect calculations.
thrills4ever
A ball, which we can treat as a point charge, has a charge of +Q and a weight of 9.00 N. This ball is 50 cm away from a ball of charge -10Q, which is fixed in position. The +Q ball is 30 cm vertically below, and 40 cm horizontally, from the other ball, and the +Q ball is held in equilibrium at that position by a string which happens to be perfectly horizontal
Image: http://www.webassign.net/userimages/81225?db=v4net
1) What is the magnitude of the electrostatic force that the ball with the charge of -10Q exerts on the ball with the charge of +Q?
2) What is the magnitude of the tension in the string?
3) What is the value of Q?
Fn = mgcos0
Fe = k(q1)(q2)/r^2
Fw = mg
I know this problem needs to be broken down into components, so I started off trying to figure out how to break up the Forces by drawing a free body diagram. On the -10Q ball there is Fn pointing upwards and mg directed downwards correct? To get the diagonal force I have to use mgcos0 which becomes mg(30/50)...I do not know if this is correct because I am trying to sum up all the forces in the x direction and all the forces in the y direction. As for finding the tension, I know it involves the same kind of process but I am confused on where to start since I think I need the answer to 1). with that answer I will be able to find answer 3 using coulomb's law.
Thanks for all the help!
To answer part 1, why don't you just directly solve your second equation? You have q1, q2, and you can easily find r.
i don't know the value of q though.
Draw a free body diagram for +Q. Three forces are acting on +Q: the electrostatic force by -10Q, the force of gravity, and the tension in the string. Resolve the electrostatic force, Fe, into vertical and horizontal components. The vertical component of this force must be equal and opposite to the weight, and the horizontal component must be equal and opposite to the string tension. With these equations, Fe and T can be found.
chrisk thanks for the help, I figured it out in like 5 minutes..I can't believe didnt realize it before.
9K
