Goldstone1
- 113
Suppose I have a mass M_0 (here denoted with lowercase zero because of previous discussions on relativistic mass), and I have a gravitational field \phi which can under make a shift of 180^o between a negative plane and a positive plane. Assume also that the mass is considered as a charge, rather than something being separate to it, and then:
\Delta E \Psi= \sum_{i}^{\theta} M_{0i} \phi (\Lambda^{-1} x) \psi_i
The question is the coupling. Since the boundary of the sum is the shift of -sin \theta and -cos \theta then \phi is related to the mass by the probability coupling field \Psi. Have I made my coupling correctly?
