Connecting Geodesic Curves and the Covariant Derivative
In summary, Carrol's notes state that the covariant derivative of a vector is given as ∇μAϑ=∂μAϑ+ΓϑμλAλ...(1)
Apashanka
429
In Carrol's gr notes the covariant derivative of a vector is given as ∇μAϑ=∂μAϑϑμλAλ...(1)
For a geodesic in 2-D cartesian coordinates the tangent vector is V=##a\hat x+b\hat y##(a and b are constt.)where the tangent vector direction along the curve is ##\hat n=\frac{a\hat x+b\hat y}{\sqrt{a^2+b^2}}##
Now , covariant derivative of a tangent vector along the tangent vector direction for a geodesic is 0.
e.g ##\nabla_\hat nV=0##...(2)
Now how to relate (1) and (2) can anyone please suggest
  • grnotes-three.pdf
For a geodesic curve in 2-D polar coordinates(r,θ) the tangent vector is ##V=\hat r## ,therefore the tangent vector direction is ##\hat r## which we call say 1.
and ##\hat \theta## as 2.
The covariant derivative is therefore ##\nabla_1V=0=∂_r (V)+( )=∂_r(\hat r)+( )=0+() ##
I am in trouble writing out the bracketed term which is ##\Gamma_{1?}^?##
Can anyone please help in sort out this
Could you please help in sort out ...@PeterDonis
This is not correct in general. The only curves whose tangent vectors are ##\hat r## are straight radial lines through the origin.
I do not think you know what a tangent vector is. The tangent vector to a curve is a vector pointing in the instantaneous direction you would face if you were walking along that curve. This does not have anything to do with your coordinates or your basis vectors.
I have mentioned geodesic curve
So? Radial lines through the origin are not the only geodesics of a 2d Euclidean plane. All straight lines are geodesics.
I think you need to learn this stuff from another source. Carrol's notes are not intuitive most of the time.
Here I have taken a curve in 2-D(r,θ) with it's one end at the origin parametrised by λ(length along that curve) where at origin λ=0.
For this curve to be geodesic the components of tangent vector are ##V^1##=dr/dλ= 1 along ##\hat r## and ##V^2##=dθ/dλ=0 along ##\hat \theta##,so that the tangent vector is V=##\hat r##.
So what's the problem here...
And from the geodesic definition ##\nabla_\hat r V=\nabla_\hat r (V^ie_i)=\nabla_\hat r (e_1)=0## that's what I need to prove
My motto is to find how this covariant derivative for tangent vectors work ,,that's why I have taken the simplest example..
The problem here to me is how to decompose the term ##\nabla_\hat r##??(e.g covariant derivative along ##\hat r##)
Can anyone please suggest
@Ibix is not saying that straight lines through the origin are not geodesics— he’s simply stating that those geodesics form a small subset of all geodesics on a flat plane. So in general the tangent vector of a geodesic using polar coordinates does not equal ##\hat r##.
Likes Ibix
The covariant derivative along a curve with tangent vector ##V^\mu## is ##V^\mu \nabla_\mu##.
There is an ambiguity in your statement. You talk about "a geodesic curve in 2-D polar coordinates". You haven't specified a connection, and I'm not sure if you are familiar with the concept of a connection. This is unfortunate, because the covariant derivative isn't uniquely specified unless one defines a connection.
Now, in GR, it is implied that when we talk about a "geodesic curve", we use the Levi-Civita connection. Often, we get lazy about stating this explicitly. If we assume that's what you meant, then there is a subset of geodesic curves in the plane, namely those geodesic curves that pass through the origin, that have a tangent vector of ##\hat{r}##.
However, there are also a large set of geodesic curves with the Levi-Civita connection that don't pass through the origin, and whose tangent vector is something different.
What I think is probably happening is that when you are talking about 'using 2-D polar coordinates', you really mean that you are using a connection other than the Levi-Civiti connection. But I could be wrong about what you're trying to say.
The most striking thing about your posts is that you seem to think that specifying the coordinates matters. It doesn't. Once we specify that we are using the Levi-Civiti connection on the plane, geodesic curves are always the curve of shortest distance between two points. This is hopefully familiar an intuitive.
Then the point is that he curve that is the shortest distance between two points on the plane exists, and is independent of the coordinates used. We don't need to talk about whether we are using polar coordinates or cartesian coordinates to talk about the curve that is the shortest distance between two points.
What I suspect is happening is that you are wandering into the realms of connections other than the Levi-Civita connection without realizing it. Circles about the origin, curves with a constant value for the r coordinate, are not geodesics in the Levi-Civita connection, but may be geodesics with some other connection. But when one opens up the possibility of using connections other than the Levi-Civita connection, one needs to realize that covariant derivatve operators are not unique.
I suspect that it's least confusing at this point to restrict oneself to the Levi-Civiti connection on the plane (or other flat manifolds), as a steppingstone to talking about geodesics with the Levi-Civita connection on manifolds that are not necessiarly flat, and then moving onto using connections that aren't the Levi-Civita connection. But this is not the only way to do things, it's just the way that I'd recommend.
Likes Dale
What is a covariant derivative?
A covariant derivative is a mathematical operator that is used to measure how a geometric object changes as it moves along a curved space. It takes into account the curvature of the space and allows for the calculation of rates of change in a way that is consistent with the underlying geometry.
What is the difference between a covariant derivative and a regular derivative?
A regular derivative measures the rate of change of a function with respect to one variable. A covariant derivative, on the other hand, measures the rate of change of a geometric object as it moves along a curved space, taking into account the curvature of the space.
How is a covariant derivative calculated?
The calculation of a covariant derivative involves using a connection, which is a mathematical tool that describes how to compare vectors at different points on a curved space. The connection is used to define a covariant derivative operator, which then acts on the geometric object to calculate its rate of change.
What is the importance of covariant derivatives in physics?
Covariant derivatives are important in physics because they allow for the description of physical laws in curved spaces, such as in general relativity. They also play a crucial role in the formulation of gauge theories, which are used to describe fundamental interactions in particle physics.
Can covariant derivatives be generalized to higher dimensions?
Yes, covariant derivatives can be generalized to higher dimensions. In fact, they are an essential tool in the study of higher-dimensional spaces, such as in string theory and other areas of theoretical physics.
  • Differential Geometry
