Crank/Piston Motion: Understanding dB/dt, dB/dθ & d2B/dT2
  • Context: MHB
  • Thread starter Thread starter tomc612
    Motion
The discussion revolves around the mathematical modeling of crank/piston motion, focusing on the relationships between various derivatives of a function representing the motion. Participants explore the equations governing the motion, including the use of the Law of Cosines, chain rule applications, and optimization problems related to the parameters involved in the motion.
  • Homework-related
  • Tom presents an equation for B in terms of A, C, and θ, and asks about the relationship between dB/dt and dB/dθ.
  • Some participants propose using the chain rule to express dB/dt as dB/dθ multiplied by dθ/dt, confirming Tom's approach.
  • Tom derives a formula for dB/dθ and suggests that dB/dt can be expressed using this formula multiplied by K.
  • Another participant agrees with Tom's formula for B and provides an alternative derivation using the Law of Cosines.
  • There is a discussion about obtaining a formula for d²B/dT², with Tom indicating he has not yet derived it.
  • Tom seeks help with an optimization problem related to the values of A and C, stating he has encountered difficulties with the results being outside the expected range.
  • Participants clarify the conditions for the optimization problem, with one participant simplifying the inequalities involving A and C.
There is no consensus on the second derivative of B, as Tom has not yet derived it. Participants generally agree on the relationships established through the chain rule and the formulas presented for B, but the optimization problem remains unresolved with differing interpretations of the conditions.
Limitations include the need for further clarification on the optimization conditions and the unresolved nature of the second derivative of B. The discussion also reflects varying levels of understanding and approaches to the mathematical modeling involved.
Readers interested in mathematical modeling of mechanical systems, particularly those involving crank/piston dynamics, as well as those tackling optimization problems in a similar context.
tomc612
Hi,
Looking for some help on a crank/piston motion equation..
If a crank rotates counter clockwise measured in Radians/sec -as d\theta/dt = K T = time in secs
The arms of the crank A and B are fixed and B is the stroke length with \theta as the angle between A and B
So far I've got that B = Acos\theta + \sqrt{C^2 -(Asin\theta)^2}
Min/max for B is at \theta = 0, Pi, 2Pi.
Q. What is the relationship between dB/dt and dB/d\theta -
A. is this that dB/dT = d\theta/dT x dB/d\theta?
Q. obtain a formula for dB/dT. Answer should be in terms of A, C, \theta and K
A. dB/d\theta = -Asin\theta+ A^2sin\thetacos\theta/\sqrt{C^2 -(Asin\theta)^2}
So my question is dB/dt then simply the the above formula for dB/d\theta x K
=K(-Asin\theta+ A^2sin\thetacos\theta/\sqrt{C^2 -(Asin\theta)^2})
Q. Obtain a formula for d^2B/dT^2
A. if K is constant is that then second derivative of B x K
= B".K
Haven't got to working out the second derivative of B just yet,
any advice appreciated
Thanks
TomView attachment 6151
Hello Tom,
I think what I would do here is first use the Law of Cosines to determine $b$:
$$c^2=a^2+b^2-2ab\cos(\theta)$$
Arrange in standard quadratic form:
$$b^2-2a\cos(\theta)b+a^2-c^2=0$$
Apply the quadratic formula, and discard the negative root (since we must have $c>a$):
$$b=\frac{2a\cos(\theta)+\sqrt{4a^2\cos^2(\theta)+4(c^2-a^2)}}{2}=a\cos(\theta)+\sqrt{c^2-a^2\sin^2(\theta)}$$
This agrees with your result.
Q. What is the relationship between $$\d{b}{t}$$ and $$\d{b}{\theta}$$?
Using the chain rule, we may state:
$$\d{b}{t}=\d{b}{\theta}\cdot\d{\theta}{t}$$
We are given:
$$\d{\theta}{t}=k$$
Therefore, we obtain:
$$\d{b}{t}=k\d{b}{\theta}$$
This is where you were headed, but you didn't make the substitution for $k$.
Q. Obtain a formula for $$\d{b}{t}$$. Answer should be in terms of $a$, $c$, $\theta$ and $k$.
Okay, given that we found:
$$b(\theta)=a\cos(\theta)+\sqrt{c^2-a^2\sin^2(\theta)}$$
Differentiating w.r.t $\theta$, there results:
$$\d{b}{\theta}=-a\sin(\theta)+\frac{1}{2}(c^2-a^2\sin^2(\theta))^{-\frac{1}{2}}(-2a^2\sin(\theta)\cos(\theta))=-a\sin(\theta)\left(1+\frac{a\cos(\theta)}{\sqrt{c^2-a^2\sin^2(\theta)}}\right)$$
And so, using our result from the first question, we have:
$$\d{b}{t}=-ak\sin(\theta)\left(1+\frac{a\cos(\theta)}{\sqrt{c^2-a^2\sin^2(\theta)}}\right)$$
Now, before we move on to the final question, we can observe that our computation will be simpler if we write:
$$\d{b}{t}=\frac{abk\sin(\theta)}{a\cos(\theta)-b}$$
Now we may apply the quotient and chain rules as appropriate. :D
Hi Thanks for the help, glad to see I wasn't too far off.
One thing for the formula for B, i reached the formula by creating 'h' to represent the height of the joint of A+C, and then split B in B1 and B2 at h to create to right angle triangles.
B=B1 + B2
B1 = Acos\theta
B2 = \sqrt{C^2 -h^2}
h = Asin\theta
B2 =\sqrt{C^2 -(Asin\theta)^2}
b = Acos\theta +\sqrt{C^2 -(Asin\theta)^2}
MarkFL said:
Hello Tom,
We are given:
$$\d{\theta}{t}=k$$
Hi, Also need some help on a following question to this same problem.
need work on optimisation for the values of A+B
I tried optimising by implicit differentiation of a right and angled triangle, however the values I get are out side of the given range
12. we change the values of a and c, subject to the following requirements:
a + c = 30; and 2\le  c- 􀀀 \lea  10:
(a) What is the smallest possible value for a? What is the largest possible value for a?
Justify.
What is this line supposed to say?
tomc612 said:
...a + c = 30; and 2\le  c- 􀀀 \lea  10:...
Sorry, the question should read:
Okay, we are given:
$$c=30-a$$
And:
$$2\le c-a\le10$$
Substitute for $c$:
$$2\le 30-a-a\le10$$
Simplify:
$$2\le 30-2a\le10$$
You should be able to algebraically show this is equivalent to:
$$10\le a\le14$$
