Crankcase Scavenging: What Does it Mean for Automobiles?
  • Thread starter cyborgyash
In summary, crankcase scavenging means getting combustion products and oil vapour out of the crankcase, usually using a breather system which filters these gases and returns them to the inlet tract.
cyborgyash
What does crankcase scvenging mean in terms of an automobile ?? .I searched all around the net but didn't get single satisfactory result.
Getting combustion products and oil vapour out of the crankcase, usually (these days) using a breather system which filters these gases and returns them to the inlet tract. A google search gave me dozens of good references, what kind of 'satisfactory' result do you need?
I think your are referring to crankcase vacuum in a race engine.
Specifically, if you run a dry sump system with a three stage pump (one pressure stage, two scavenge stages), in most cases you cannot achieve a sufficient level (8 "HG) of crankcase vacuum to achieve that power gain. If you go to a four stage pump you can gain 2 HP per cylinder. The reduced pressure ("vacuum") in the crankcase is generated by having a substantial excess of scavenging capacity with respect to the engine's oil flow rate. The "vacuum" increases the pressure differential across the ring package, producing an improved ring seal. The improved ring seal allows the use of a low-tension (reduced friction) ring package, yielding a power increase as well. Further, the reduced crankcase pressure dramatically reduces windage losses at high RPM. In most engines, the expected power gains will occur with 8 to 10 inches HG crankcase vacuum. Beyond that point, more vacuum does not generally produce any measurable power gain until (a) you get more than 20 inches HG of vacuum AND (b) you are operating in excess of approximately 8300 RPM. Generally you size the system to produce around 14 "HG when the engine is fresh. That provides sufficient capacity so that as the engine wears and blowby increases, there will still be sufficient scavenging capacity to achieve the 8"HG minimum, and power does not drop off noticeably. If you want to run a high level of crankcase vacuum (18 inches HG or more), there must be provisions in the engine to supplement the lubrication that is lost due to windage. There will likely be problems with at least wrist pin and cam follower lubrication. The best solution will be the addition of piston oilers and, if your engine has a flat tappet cam, provisions for extra lubrication of the cam lobe-to-lifter interface will certainly be required. If you are trying to achieve over 18 "HG, you will need to install special crankshaft seals (front and rear) which have the sealing lips reversed to hold that higher level.
Thankyou both for your replies, especially Ranger Mike. But, i could make the definition for me to understand very well, by seperately reading meaning of "Crankcase" in depth and then "Scavenging". Adding bothe the definions you'll know about Crankcase Scavenging. ^_^
1. What is crankcase scavenging?
Crankcase scavenging is a process in which the air-fuel mixture is removed from the combustion chamber of an engine by the movement of the piston. It is an important aspect of engine design and is responsible for improving engine efficiency and reducing emissions.
2. How does crankcase scavenging affect automobile performance?
Crankcase scavenging has a direct impact on the performance of an automobile. It helps to improve fuel efficiency, increase power output, and reduce emissions. It also helps to prevent engine knocking and improve overall engine longevity.
3. What are the different types of crankcase scavenging?
There are two main types of crankcase scavenging: positive and negative. Positive crankcase scavenging uses a pump to force the air-fuel mixture into the combustion chamber, while negative crankcase scavenging relies on the natural movement of the piston to draw the mixture into the chamber.
4. How does crankcase scavenging impact emissions?
Crankcase scavenging plays a crucial role in reducing emissions from automobiles. By efficiently removing the air-fuel mixture from the combustion chamber, it helps to reduce the amount of unburned fuel and harmful pollutants that are released into the environment.
5. What are some common challenges with crankcase scavenging?
One of the main challenges with crankcase scavenging is achieving optimal scavenging efficiency. This requires careful design and engineering to ensure that the air-fuel mixture is properly removed from the combustion chamber without causing any unwanted side effects, such as reduced power or increased emissions.
  • Mechanical Engineering
