surendranadh
- 1
creating artifical gravity by using centripetal force what is the formula g value
Moderato said:So what I don't get is what the spin is relative to. That's easy when you have nearby planetary systems, but when you get into deep space, any distant objects would, to all intents and purposes, have no influence on the 'gravity' being generated by the spinning of the station. So what defines the spin rate then? Surely not systems that are light years away. Does space-time itself have some fixed structure by which the spin is measured, perhaps?
Nugatory said:Speeds are always relative - you have no way of knowing whether you're moving except by comparing with some external object to see if you're moving relative to it - but accelerations are not. If you were in a sealed box, no windows, no way of looking out, you'd have no way of knowing whether you were at rest or not but you'd still be able to detect (non-gravitational) accelerations using a weight on a spring or an accelerometer.
Rotating movement is accelerated movement; the centripetal force is accelerating everything towards the center. Thus, you don't need any external reference to experience it.
Rotating reference systems are not inertial. One can determine rotation rate and direction without reference to any external bodies. One could well say that rotation is absolute, not relative.Moderato said:However, as you said - speeds are always relative - but by the same token, so is rotation.
Rotation is not relative.Moderato said:However, as you said - speeds are always relative - but by the same token, so is rotation.
It depends on the situation and the observations that we can make. If we can measure the centripetal acceleration in the other system - maybe someone there set up an accelerometer that we can read, maybe we can watch an object dropped in the other system - then we can measure the rotation of the other system directly. The answer will come out the same no matter what our rotation rate is, so we don't need to measure ours first. (That we can measure it and get the same result no matter what ours is, is another way of saying that it is not relative).Moderato said:So we can only accurately measure the rotation rate of another system by first measuring our own?
Moderato said:So... when there is no detectable rotation within your system, you can detect the rotation of other systems by observation, but that makes the rotation of the other system measurable relative to your non-rotating system does it not? But rotation is not relative...
Or are you saying that you can't measure the rotation of another system accurately by observation from outside of that system - the measurement has to be made from within the rotating system and then 'broadcast' to other systems? In other words visual observation of rotation will result in inaccurate measurements?
That seems like a logical conclusion. In principle, you could use masses on strings on three axes and go for zero tension. Another object that appears to be spinning is Really spinning. ?Moderato said:So... when there is no detectable rotation within your system, you can detect the rotation of other systems by observation, but that makes the rotation of the other system measurable relative to your non-rotating system does it not? But rotation is not relative...
