Creating a Buffer pH of 9.23: Step-by-Step Guide
  • Thread starter Thread starter CivilSigma
    Buffer
To create a buffer with a pH of 9.23 using 0.200 M HCOOH and 2.00 M NaOH, the correct volumes need to be calculated based on the desired pH and the pKa of the acid used. The initial calculations provided were based on benzoic acid, which is not applicable since the discussion focuses on formic acid (HCOOH). The ratio of weak conjugate base to weak acid was incorrectly stated as 5.31, which needs to be recalculated for formic acid. Clarification on the pKa value used is necessary to ensure accurate pH determination. Accurate calculations and ratios are essential for successfully assembling the buffer solution.
CivilSigma
Hello, I have the following problem:
What volumes of 0.200 M HCOOH and 2.00 M NaOH would make 500.0 mL of a buffer with the pH of one made from 475 mL 0.200 M benzoic acid and 25 mL of 2.00 M NaOH?
I have determined that the pH of the buffer should be 9.23. Now, I am stuck on how I would assemble the buffer. Moreover, I determined that the ratio of the week conjugate base to week acid is 5.31 ( CH3COO / CH3COOH ).
What do I need to do next?
Thanks.
I am afraid that's not what I got, What value of pKa for benzoic acid have you used? And how you got 9.23? Please show.
For the pH 9.23 that's orders of magnitude off. For the real pH of the buffer order of magnitude is OK, but the value is wrong. Besides, question asks for HCOOH, not CH3COOH (and the ratio is wrong for both acids).
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
