Creating convergent sequences in Banach spaces
ScroogeMcDuck
Sorry for the rather vague title!
Given:
  • Two Banach spaces A and B, and a linear map T: A\rightarrow B
  • The sequences (x^n_i) in A. For each fixed n, (x^n_i) \rightarrow 0 for i \rightarrow \infty.
  • The sequences (Tx^n_i) in B. For each fixed n, (Tx^n_i) \rightarrow y_n for i \rightarrow \infty.
  • The sequence (y_n) in B, with y_n \rightarrow y for n \rightarrow \infty.
Problem:
I need to create a sequence w_n in A, for which w_n \rightarrow 0 and Tw_n \rightarrow y in B.
So for the sequence y_n of limits of Tx_i^n we know:
\forall \epsilon>0 \, \exists m \in \mathbb{N} such that \forall n ≥ m: ||y_n - y||<\epsilon
And for a fixed n, we know:
\forall \epsilon>0 \, \exists m_1=m_1(n) \in \mathbb{N} such that \forall n ≥ m_1: ||x_i^n||<\epsilon
\forall \epsilon>0 \, \exists m_2=m_2(n) \in \mathbb{N} such that \forall n ≥ m_2: ||Tx_i^n - y_n||<\epsilon.
Furthermore T is not necessarily continuous (it would be trivial if it were).
I tried using the sequence w_n = x_n^n. Proving that Tw_n \rightarrow y then required me to prove that \forall \epsilon>0 \, \exists n' \in \mathbb{N} : \forall n≥n': ||Tx_n^n - y_n||< \epsilon/2 (so that I could use the triangle inequality afterwards), but I couldn't manage this since y_n is not fixed.
I also tried using w_n = x^n_{m_3(n)} where m_3(n) = max\{m_1(n),m_2(n)\}. The required convergence did work out, but then I realized that m_1(n) and m_2(n) depend on \epsilon as well as n, so my sequence depends on \epsilon which is of course not as it should.
Any suggestions, hints, ideas would be appreciated!
So your problem is that you essentially have three sequences, and you need to get some kind of uniform control of them. Passing to subsequences is obviously (?) the way to go, but you're running into trouble with your subsequences being dependent on an arbitrary \epsilon.
I suggest using the following fact about metric spaces to get a little better control over your subsequences:
If u_n\rightarrow u, then there is n_1<n_2<...<n_j<... such that d(u_{n_j},u)<j^{-1} for all j=1,2,....
I.e. there is always a "nice" subsequence that converges in a controlled way. I think you can use that fact to remove your \epsilon troubles. I'd also suggest making use of the trusty "WLOG" in order to make your notation manageable; since we know we can find a "nice" subsequence, we may as well assume WLOG that the original sequence was already "nice".
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
