Creation/Anhilation Operator Exponential Commutator Relation
The discussion focuses on proving the commutation relations involving creation and annihilation operators, specifically showing that [a, f(a, a^\dagger)] = ∂f/∂a^\dagger and [a, e^{-\alpha a^\dagger a}] = (e^{-\alpha}-1)e^{-\alpha a^\dagger a}a. Participants express difficulty with the algebraic manipulation and proper ordering of operators due to their non-commuting nature. They emphasize the importance of anti-normal ordering and suggest verifying the formula for simple monomials before tackling the exponential case. The conversation concludes with a methodical approach to proving the relations through differentiation and the use of operator-valued functions.
teroenza
Given that the function f can be expanded in a power series of a and a^\dagger, show that:
[a,f(a,a^{\dagger})]=\frac{\partial f }{\partial a^\dagger}
and that
[a,e^{-\alpha a^\dagger a}] = (e^{-\alpha}-1)e^{-\alpha a^{\dagger} a}a
I've tied using simple algebra, but got nowhere. Writing the exponential operators as infinite sums did not seems to be leading to an equality either. I am not sure how to correctly order the result of the derivative resulting from the first equation. I.e. e^{-\alpha a^{\dagger} a}(-\alpha a) or (-\alpha a)e^{-\alpha a^{\dagger} a}.
Perhaps check first that the formula holds for simple monomials of the form f=a^m (a^\dagger)^n .
Ok. I think part of my problem is that I'm not clear on how to series expand a multivariable function. From
http://en.wikipedia.org/wiki/Power_series#Power_series_in_several_variables
I think (if I'm reading the notation right) that:
f(a,a^{\dagger})=\sum_{i=0}^{\infty} \sum_{j=0}^{\infty}c_i c_ja^i (a^{\dagger})^j.
Before looking at it in terms of series, I had tried to show that:
[a,a^m(a^{\dagger})^n] = a^{m+1}(a^{\dagger})^n-a^m(a^{\dagger})^na = \frac{\mathrm{d} f}{\mathrm{d} a^{\dagger}}=a^mn(a^{\dagger})^{n-1}
You must be careful. The Wiki entry is for power series with commuting variables, while a and a^\dagger do not commute. You need to fix the ordering. Putting first powers of a, then powers of a^\dagger is called anti-normal ordering. Remember the rule:
[A,BC]=B[A,C]+[A,B]C
Then calculate
[a,a^\dagger ]=1
[a,(a^\dagger)^2]=a^\dagger [a,a^\dagger]+[a,a^\dagger]a^\dagger=2a^\dagger
[a,(a^\dagger)^3]=a^\dagger[a,(a^\dagger)^2]+[a,a^\dagger](a^\dagger)^2=3(a^\dagger)^2
[a,(a^\dagger)^n]=n(a^\dagger)^{n-1}.
[a,a^m(a^\dagger)^n]=a^m[a,(a^\dagger)^n]+[a,a^m](a^\dagger)^n=a^m[a,(a^\dagger)^n]=na^m(a^\dagger)^{n-1}.
Ok. So I need to pick an ordering and stick with it. I'm not sure how to make the jump from the monomial to the exponential. Perhaps thinking of the commutator as [a,(e^{- a^{\dagger}a})^{\alpha}]? But that seems just as bad, because I would need to know [a,e^{- a^{\dagger}a}]
Look at the formula you need to prove: <br /> [a,e^{-\alpha a^\dagger a}] = (e^{-\alpha}-1)e^{-\alpha a^{\dagger} a}a
Expand the commutator on the LHS, expand the parenthesis on the RHS. Simplify. Multiply both sides by e^{\alpha a^{\dagger} a} form the left. You will get a simpler formula that can be proven in several ways.
Since the usual way to expand the LHS commutator would mix the ordering, the only way to expand the commutator would be to use what I proved before and use the derivative.
e^{-\alpha a^\dagger a}(-\alpha a) = e^{-\alpha(1+aa^\dagger)}a - e^{-\alpha a a^\dagger}
I will use t instead of \alpha, because \alpha is too similar to a.
You messed up. LHS=[a,e^{-t a^\dagger a}]=ae^{-t a^\dagger a}-e^{-t a^\dagger a}a.
RHS=e^{-t}e^{-t a^{\dagger} a}a-e^{-t a^{\dagger} a}a. Therefore you need to show that ae^{-t a^\dagger a}=e^{-t}e^{-t a^{\dagger} a}a. Multiply from the left by e^{t a^\dagger a} taking into account the fact that e^{-t} is a c-number, thus commutes with any operator. You need to prove that
e^{t a^\dagger a}ae^{-t a^\dagger a}=e^{-t}\,a
Define f(t)=e^{t a^\dagger a}ae^{-t a^\dagger a}. This is an operator valued function of a real variable t. Verify that f(0)=a. Now calculate the derivative with respect to t. You can use the chain rule, but you must pay attention to the order of noncommuting operators. You get
f&#039;(t)=e^{t a^\dagger a}(a^\dagger a) a e^{-t a^\dagger a} -e^{t a^\dagger a}a(a^\dagger a) e^{-t a^\dagger a}=e^{t a^\dagger a}[a^\dagger a, a] e^{-t a^\dagger a}
The commutator you already know, and it is -a. Therefore f(t) satisfies the differential equation f&#039;(t)=-f(t).
Check that the RHS satisfies the same differential equation. Check the initial values are the same. From the uniqueness of solutions of first order linear differential equations you have that LHS=RHS for all t.
Thank you so much for your help.
  • · Replies 26 ·
