Cross products vanish Classical Mechanics
The discussion centers on the vanishing of cross terms in the context of an object moving in the x-y plane, specifically referencing equation 8.9. The key reason for this is the definition of the center of mass, which simplifies the calculations in the center of mass frame of reference. Participants suggest examining equations 5.56 and 5.58 for further clarity, emphasizing that in this frame, the position vector r' becomes zero. A question arises regarding the integral of the cross product of r' and v', prompting a deeper exploration of the mathematical implications. Understanding these concepts is crucial for grasping the mechanics involved in the problem.
KEVmathematics
As seen in the picture, this question is about an object moving in the x-y plane. But I don't get why in equation 8.9 the cross terms vanish? If anyone can help me, that would be really nice.
... they vanish due to the definition of "center of mass".
The text explains with maths in the passage right below eq8.9.
Have you tried working out the cross terms for some example?
The book answers your question already. You need to think about the center of mass in the center of mass frame of reference. Also the author suggests hou look at equation 5.56
Equation 5.58 is just R_cm = sum m_i r_i / M.
I get why r' is zero in the frame of the center of mass. But if that's the case, why is the integral of the cross product of r' and v' not equal to zero also?
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
