Crosswind problem (pgs. 34-35, Thinking Physics, 3rd edition)
327 replies · 22K views · last reply
erobz said:
You cannot propel something initially and expect a chain reaction to occur. Momentum entering the vane as ##-v_y## would counter the momentum it was gaining from changing the direction of ##w##. The very momentum that is driving it.
You requested mathematical rigor, but when the math contradicts your intuition, you are making excuses why you won't accept it. I'm just asking you to be consistent for both axes x & y.
erobz said:
In still air you cannot push something with a sail and expect it to accelerate away from you.
Correct, but we are not talking about no wind. We are talking about your own scenario with wind ##w## along the positive x-direction. Post #57 explains why it doesn't work without wind relative to the ground.
erobz said:
If I turned the vane as you wish, having it scoop air, and gave it a shove, it would scoop mass from the ##y## direction and sent it to ##-x## direction, thus providing an impulse, which would scoop more mass, and give another impulse, ad infinitum. It just doesn't work like that.
That is exactly how it works. That's why there is no fixed limit on the windspeed multiple a sailcraft can achieve, and this applies to the downwind component as well.
But there are practical limits. As you accelerate, the relative flow comes more and more from the front, so you need increasing high lift/drag ratios to still produce a forward force component (see post #57). The achievable lift/drag ratios for the interactions with the air and the surface are limiting the speed of a sailcraft.
erobz said:
...It is effectively a fluid jet impinging on a sail in the vacuum of space...
Fortunately the real wind is a large moving airmass that extends in all directions, so it doesn't have the limitations of such a thin jet model. Just use a very wide jet instead.
Thats exactly how it works my foot. You cannot give a sail craft an initial shove in still air and have it accelerate away. That is absolutely ludicrous!
erobz said:
,,,in still air ,,,
Why do you misrepresent what I am saying. I stated many times, that it doesn't work without wind relative to the ground and explained why:
A.T. said:
If true_wind = 0 then apparent_wind = -boat_velocity. So even a infinite lift/drag ratio won't produce a forward_force. The sail_force can be at most 90° from the apparent_wind.
Four vector diagrams of a sailboat in plan view: boat velocity with downwind VMG equal to 1.5 times wind speed, true and apparent wind with induced wind, and sail lift, drag and forward force components.
in reply to;
erobz said:
If I turned the vane as you wish, having it scoop air, and gave it a shove, it would scoop mass from the y direction and sent it to −x direction, thus providing an impulse, which would scoop more mass, and give another impulse, ad infinitum. It just doesn't work like that.
Yes, that is exactly how it works, if there is wind relative to the ground.
You say this is so trivial early on, but then give no foundational proof. Your idea of mathematical rigor is " just look at the (arbitrarily drawn) vectors on the diagram"!
That doesn't cut it. Color me unconvinced. Good day to you.
erobz said:
You say this is so trivial early on, but then give no foundational proof. Your idea of mathematical rigor is " just look at the arbitrarily drawn vectors on the diagram"!
What about the vectors is wrong? The only assumption there is a lift/drag ratio of about 5, which is very conservative. Airfoils reach 20 and more.
If I gave the boat a shove in still air in the direction of the "true wind" in your diagram, that would produce relative flow over the air foil in the direction of the "apparent wind", that in turn would provide a force that accelerated the boat in the direction of the lift force (increasing its velocity), which would increase the sail force by way of increasing the apparent wind! ##\circlearrowright##. So in that case (absence of a drag force on the air foil - a function of the apparent flow velocity) the craft would accelerate away from me indefinitely. Now...add in the drag force. A drag force ( since you are talking about drag/lift ratio ) would grow (from 0) such that its component in the direction of the boats velocity matched the component of the lift force, thus accelerating away from me for a while, approaching moving away from me at a constant velocity.
In "still air" the "true wind" vector is zero. It doesn't have a direction. Can you draw vector diagram of what you mean?
If true_wind = 0 then apparent_wind = -boat_velocity. Since sail_force cannot be more than 90° from the apparent_wind, it cannot have a positive component in the direction of boat_velocity.
So if true_wind = 0 there cannot be a propulsive forward_force from the sail, no matter how much you push initially. There is nothing in the diagram that suggests it would accelerate without true_wind relative to the ground.
Four-panel vector diagram of a sailboat in cross-section: boat velocity and true wind arrows, apparent and induced wind arrows, and sail lift, drag and forward force components resolved from the sail force.
Your diagram is just arbitrarily drawn vectors that have scant applicability to a proper momentum transfer analysis. The wind applies a force to the sail. In Newtonian Mechanics we talk about forces, the wind force on the sail is not fully described by the wind vector in your diagram. The force on the sail depends on how it deflects the incident momentum from the wind. That is what determines which way and how much the boat accelerates.
The "apparent wind" in still air in your diagram would be the component of the boats velocity in the direction of the sail. That was your whole argument about scooping momentum from the ##y## direction by turning my vane clockwise 90 degrees. If there is apparent wind from me giving it initial velocity the airfoil produces lift. If there is lift ##\circlearrowright##. Perpetual motion ensues.
Yes, as shown in both bottom diagrams as sail_force.
erobz said:
... the wind force on the sail is not fully described by the wind vector in your diagram.
The sail_force direction is fully determined by the apparent_wind direction and the lift/drag ratio (assumed to be ~5 here).
Wrong. The vector math is:
apparent_wind = true_wind - boat_velocity
For true_wind = 0 you have apparent_wind = -boat_velocity. And since sail_force cannot be more than 90° from the apparent_wind, it cannot have a positive component in the direction of boat_velocity. So no acceleration is possible without true_wind.
Four vector diagrams of a sailboat in plan view. Top left: boat velocity arrow, true wind arrow, and downwind VMG = 1.5 wind speed. Top right: apparent wind, true wind and induced wind vectors. Bottom left: sail force split into sail lift force and sail drag force. Bottom right: sail force split into a forward force component.
Sorry, that's not how the dot product works.
If there were no wind and I push the boat in the direction shown in your diagrams, the "apparent wind" (from the perspective of the sail) would have magnitude ## |v| |s| \cos \theta## and direction opposite the direction of motion.
This is exactly the fact that allows planes to fly in still air.
There is no dot product here. It's just vector subtraction:
Your magnitude computation is confused, but the key is that you got the direction right:
If true_wind = 0 then apparent_wind is exactly opposite to the direction of motion.
And since sail_force cannot be more than 90° from the apparent_wind, it cannot have a positive component in the direction in the direction of motion. So no acceleration is possible without true_wind.
A.T. said:
There is no dot product here. It's just vector subtraction.
The apparent wind in still air is the projection of ##\vec v ## onto ##\vec s##. That is not debatable. ( I should clarify ##\vec s ## is a unit vector)
Diagram of a blue sailboat seen from above with a red velocity arrow labelled v pointing up and left, a green unit vector arrow labelled s along the boom, and angle theta between them.
Maybe you misunderstand the sailing terms, so let me translate into in physics terms:
boat_velocity = velocity of boat relative to the surface
true_wind = velocity of airmass relative to the surface
apparent_wind = velocity of airmass relative to the boat
Thus per Galilean transformation the vector relationship is:
There is no projection involved.
##\vec v## has components parallel and orthogonal, to ##\vec s##. It is the component of ##\vec v##, parallel to the chord ## \vec s## that is responsible for lift, hence the dot product.
You are confusing lift with normal force. Lift and drag are defined based on the relative flow direction (apparent wind), not based on the chord:
Diagram of an airfoil at angle of attack alpha in a free stream V-infinity moving left to right, with lift L and drag D shown as dashed arrows, normal force N and axial force A as solid arrows, and resultant R shown dashed.
Difference between lift (L) and drag (D) versus normal force (N) and axial force (A)
From: https://aerospaceweb.org/question/aerodynamics/q0194.shtmlThe direction of the apparent_wind is not affected by how you orient the sail, just by true_wind and boat_velocity per Galilean transformation:
the apparent wind is coming in the direction of ##\vec A##. In the case of no wind it is equal in magnitude opposite in direction to the component of ## \vec v ## in the direction of ##\vec A## ( ##\vec s ## in my diagram ).
No, your ##\vec s ## (sail orientation) is completely irrelevant to the apparent wind direction. Only the relative velocities matter in the Galilean transformation:
Note that these are free stream velocities, not the air motion deflected by the sail. But that is also how lift is defined: as perpendicular to the free stream relative flow.
Oh, so you are saying that the vectors on your diagram don't have any relevance to the forces acting on the sail?
Four-panel diagram of a sailboat in a sailing-wind vector analysis: boat velocity and true wind arrows, sail lift and drag forces, sail force resolved into forward force, and apparent wind, induced wind and true wind vectors.
On the contrary. The apparent_wind vector in my diagram is very important for the sail_force, as already explained:
But it seems you fail to understand that apparent_wind is not defined based on the sail orientation, but on the motion of the freestream airmass in the rest-frame of the boat. It's a function of boat_velocity and true_wind only.
The sail in the diagram is just for informal reasons, shown roughly how you would orient it to maximize lift/drag ratio. But the motion freestream airmass is not affected by the sail setting.
A.T. said:
On the contrary. The apparent_wind vector in my diagram is very important for the sail_force, as already explained:But it seems you fail to understand that apparent_wind is not defined based on the sail orientation, but on the motion of the freestream airmass in the rest-frame of the boat. It's a function of boat_velocity and true_wind only.
In the absence of wind, the apparent wind is the boat velocity (opposite it). The component of the free stream velocity parallel to the airfoil is flowing over the air foil. It is generating lift.
Correct
erobz said:
The component of the free stream velocity parallel to the airfoil is flowing over the air foil, that is generating lift.
What "generates" lift is topic of lengthy discussions you can read on this and other forums, but irrelevant here.
How lift is defined is key: Lift is the force component perpendicular to the free-stream relative flow (apparent_wind). And that's what the force vectors are based on in my diagram, not on the sail orientation.
A.T. said:
Correct
Well, that's a deceptive diagram in my opinion.
I agree that one could make the sail orientation and apparent_wind more distinct. But then some will complain, that with such a large angle of attack you could never achieve the shown lift/drag ratio. The other alternative is not to show the boat and sail at all, just the vectors.
So now that this is clarified, do you understand how it works?
No. I can't get from where I started to there.
I've shown (I believe correctly) in the vacuum of space a cart on a frictionless track can't outrun the jet of fluid pushing it with momentum change. Obviously, the models are absent the force of lift. Turning the vane around clockwise 90 deg. ( as you suggest) is detrimental to your argument. The momentum change goes from applying a force ##\nearrow## to applying a ##\searrow## to the cart.
If lift is somehow the answer, it's a long way from where I'm at.
Oh, and to one of your earlier posts about modeling the thickness of the jet ( you said something like the thin jet was the problem and I needed a thick one) The "wind" would be analogous to an array of jets, which the cart was intersecting as it passed by, taken in the limit as the distance between each jet goes to zero, we get a reasonable approximation for wind in my opinion.
Ok, but do you understand that if lift/drag ratio of 5 is empirically possible, then based on the diagram, you still can have a propulsive force, when the downwind velocity component is 1.5 x true wind-speed?
erobz said:
I 've shown ( I believe correctly) in the vacuum of space a cart on a frictionless track can't outrun the jet of fluid pushing it with momentum change.
If you insist on using a thin jet, then you have to make your sail very large instead. This would look something like this animation
But a ##\searrow## force will propel your cart forward, if ## \theta < 45° ##. And this will also happen when ## v_x = w ##, where the relative flow into the vane is along negative y direction. Of course you need a wide jet here, like the actual wind. To go even faster you have to turn the vane further clockwise, and make it less curved. As already explained, deflecting the air by 90° is very inefficient.
Free-body diagram of a curved vane on a frictionless track inclined at angle theta, with incoming jet mass flow rate mw-dot, velocity components vx and vy, and labelled force and momentum flux arrows.
A.T. said:
Ok, but do you understand that if lift/drag ratio of 5 is empirically possible, then based on the diagram, you still can have a propulsive force, when the downwind velocity component is 1.5 x true wind-speed?If you insist on using a thin jet, then you have to make your sail very large instead. This would look something like this animation
I'll solve for 45 degree turn tomorrow. Im burned out.
Just to be clear, I meant ## 0° < \theta < 45° ##. For the ## v_x = w ## case you can keep your 90° deflection vane, just rotate it by 90° clockwise, so it deflects the relative flow from -y to -x.
It should be obvious right away that this slows down the air relative to the ground, so it removes energy from the ground-air system.
