- 4,327
You requested mathematical rigor, but when the math contradicts your intuition, you are making excuses why you won't accept it. I'm just asking you to be consistent for both axes x & y.erobz said:You cannot propel something initially and expect a chain reaction to occur. Momentum entering the vane as ##-v_y## would counter the momentum it was gaining from changing the direction of ##w##. The very momentum that is driving it.
Correct, but we are not talking about no wind. We are talking about your own scenario with wind ##w## along the positive x-direction. Post #57 explains why it doesn't work without wind relative to the ground.erobz said:In still air you cannot push something with a sail and expect it to accelerate away from you.
That is exactly how it works. That's why there is no fixed limit on the windspeed multiple a sailcraft can achieve, and this applies to the downwind component as well.erobz said:If I turned the vane as you wish, having it scoop air, and gave it a shove, it would scoop mass from the ##y## direction and sent it to ##-x## direction, thus providing an impulse, which would scoop more mass, and give another impulse, ad infinitum. It just doesn't work like that.
But there are practical limits. As you accelerate, the relative flow comes more and more from the front, so you need increasing high lift/drag ratios to still produce a forward force component (see post #57). The achievable lift/drag ratios for the interactions with the air and the surface are limiting the speed of a sailcraft.
