Current at maximum power - PV cell
The discussion centers on discrepancies between the current at maximum power calculated from current-voltage characteristics and that derived from power characteristics in photovoltaic (PV) cells. The user notes that the current from the power characteristic is approximately double that from the current-voltage characteristic, which seems unusual. Clarification is sought on whether these currents should be equal, as suggested by various sources. It is indicated that the current from the power characteristic includes shunt resistance, while the current from the voltage characteristic does not. The user expresses confusion over the differing results and questions the reliability of standard models and textbooks that assert these currents should be approximately the same.
Imperatore
Hello there !
I got question regarding PV cell.
The current at maximum power Im calculated from current-voltage characteristic doesn't equal to the one calculated from P(Ushunt, as you can see in the attached picture. http://prnt.sc/b864hx
Furthermore, the Im from P(U) characteristic is about 2 times greater.
This is rather strange result for me. I am of the opinion, that these currents should be approximately equal. Maybe I am wrong and you will say it's nothing weird about these results.I hope so :)
To understand the result you need to know how the graph was arrived at.
It is my graph ;)
The current from P(U) is the current through the shut resistance, and Im from current-voltage characteristic shows the current without shut resistance. It is that what you mean?
In here http://www.instsani.pl/images/PV8.ht4.jpg you can see, that these currents are equal.
Little confused now.
OK - compare the methodology: you should find you are measuring different things, or the same thing in different circumstances.
Imperatore said:
The current from P(U) is the current through the shut resistance, and I am from current-voltage characteristic shows the current without shut resistance. It is that what you mean?
Is it that difference?
Why not check and see if your results are consistent with standard models?
From that I get:
1) Characteristic U(I):
IL=ID+ISh and ISh= 0, so IL=ID=0,5
2) Characterisitic P(U):
0,5=IL=ID+1,17(it's measured ISh), so ID=-0,67 mA
sth wrong
aby book explainig that pheno? It is written in every book I' ve examined that these two currents should be approx the same, what in my case obviously is not met.
