Current sensing and standard resistor
A user is seeking a replacement for a broken resistor in a 12v switching transformer, specifically a .01 ohm 2-watt resistor, but is struggling to find one. There is confusion over the resistor's color code, with suggestions that it might actually be brown-black-silver, indicating a resistance of 0.1 ohms instead. The discussion highlights the importance of ensuring the replacement can handle the necessary current, with a .01 ohm resistor rated for 14 A. Alternatives like paralleling .1 ohm resistors are considered, but space constraints are a concern. The power supply is used for powering battery chargers and tire truing in RC car racing.
I forgot ohms
I have a 12v switching transformer; one of the legs on a black brown silver gold 2w resistor is broken off. I have had zero luck finding a standard .01 2w resistor. I did find a current sensing resistor at the values, but should it be used. The resistor in the power supply is ceramic, I think, and bluish silver in color. Looks like the ones you would find in electronics store on the shelf but just not in .01.lol I took some EE in collage but only remember enough to be dangerous. Just wanted to be honest.
Thanks Brandon
Studiot said:
I doubt your resistor is 0.01 ohms.
Check again using this calculator
http://www.csgnetwork.com/resistcolcalc.html
That calculator doesn't have all the color bands for the multiplier. Here's a better image: http://www.google.com/imgres?imgurl...=X&ei=S7GHTdvGA4HerAHttuyzBg&ved=0CB4Q9QEwAA".
If it is a current sensing resistor, the resistance should be really small.
Are you sure the color code is black-brown-silver? Not not brown-black-silver (which would be 0.1 ohms, not 0.01 ohms).
If th current sensing resistor you have is the same resistance value as the one that broke, the only think that matters is how much current it needs to handle. A .01 ohm 2 W resistor can handle 14 A of current. Is your other resistor rating for that much?
(Really) small yes, 10 milliohms, no. That is the sort of resistance of a soldered joint so would be a waste of time for any soldered in component.
If 10 milliohms was necessary in the circuit it would most likely be formed from a carefully sized pcb track.
It is black brown silver gold. I will check the specs on other resistor. My local distributor has access to five resistor manufacturer , and not a one offer. 01 ohm 2watt. Smallest I could find is .1 ohm 2watt. I guess I could parallel a bunch of .1 but don't have the space.
The power supply is a 12-15vdc 15amp. We use them to power battery chargers and tire truer. I race 1/12 scale RC cars. The tire lathe is to cut down foam tires to achieve proper roll out.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
