Experimental Setup Ideas for Simple Cyclotron Particle Accelerators
DoubleRaven
Hi. I'm a college student, part of a group who will be doing a hands on study of particle physics next year. We plan to build a linear particle accelerator, after which we may go on to build a cyclotron. We'll be accelerating electrons to start off with.
I would like to find out more about the types of experiments that can be performed with simple cyclotron setups. All that I've encountered on the internet seems to require more energy, overly complex setups or particles we don't intend to accelerate (initially anyway).
Does anyone have any information on experimental setups that can work on more simplistic cyclotrons? Less simplistic cyclotrons produceable with a reasonable budget? What kind of information can be gained from studying electron-(molecule or atom) collisions? I imagine that the electron orbital interaction can yeild molecular energetic level information as in Electron energy loss spectroscopy (EELS)
http://www.iupac.org/publications/pac/1995/pdf/6701x0001.pdf
but don't know if this is simply and effectively implementable with our aparatus. It would be cool if it was, because what EELS has over photon spec. is the ability to probe into dipole and spin forbidden transitions.
Some of these questions are sort of engineering questions more so than QM questions, but I hope folks can help me out with some resources that I might want to look at.
Thanks
-DoubleRaven
Hi DoubleRaven,
It's great to hear about your hands-on study of particle physics and your plans to build a linear particle accelerator and potentially a cyclotron. Here are some experimental setup ideas for simple cyclotron particle accelerators that you may find useful:
1. Studying nuclear reactions: One of the main applications of cyclotrons is to study nuclear reactions. With a simple cyclotron setup, you can accelerate protons or alpha particles and collide them with a target material, such as a thin foil of a specific element. This can lead to the production of different isotopes and nuclear reactions, which can be studied using various detection techniques. This is a great way to learn about nuclear physics and the properties of different elements.
2. Measuring magnetic moment of particles: Cyclotrons use a magnetic field to guide and accelerate particles. By measuring the radius of the particle's circular motion and the strength of the magnetic field, you can calculate the particle's magnetic moment. This is an important property of particles that can provide insights into their structure and interactions.
3. Investigating electron-molecule collisions: As you mentioned, studying electron-molecule collisions can provide information about molecular energy levels and transitions. With a simple cyclotron setup, you can accelerate electrons and collide them with a gas target. By analyzing the resulting energy spectra, you can gain information about the energy levels and transitions of the gas molecules.
4. Exploring particle detectors: Cyclotrons can also be used to test and calibrate particle detectors. By accelerating particles and directing them towards a detector, you can study the detector's response and efficiency. This is a great way to learn about the different types of particle detectors and their principles of operation.
As for less simplistic cyclotrons that can be produced with a reasonable budget, you may want to look into small-scale or tabletop cyclotrons. These are compact and affordable versions of traditional cyclotrons, and they can still provide a range of experimental capabilities.
I hope these ideas give you some inspiration for your experimental setup with a simple cyclotron. As for resources, you may want to check out textbooks on particle physics and nuclear physics, as well as online resources from particle accelerator facilities such as CERN and Fermilab. Good luck with your project!
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
According to recent podcast between Jacob Barandes and Sean Carroll, Barandes claims that putting a sensitive qubit near one of the slits of a double slit interference experiment is sufficient to break the interference pattern. Here are his words from the official transcript: Is that true? Caveats I see: The qubit is a quantum object, so if the particle was in a superposition of up and down, the qubit can be in a superposition too. Measuring the qubit in an orthogonal direction might...
