Cylindrical coordinates, finding volume of solid
The problem involves finding the volume of a solid defined by the intersection of a cylinder and a sphere, specifically the cylinder described by r = a cosθ and a sphere of radius a centered at the origin. The context is within cylindrical coordinates.
  • The original poster attempts to establish the limits of integration for the volume integral, particularly questioning the limits for θ. Some participants suggest considering the geometry of the cylinder and sphere to clarify the limits.
Participants are exploring different approaches to set up the integral, with some suggesting the use of Cartesian coordinates as an alternative. There is acknowledgment of the need to clarify the limits of integration based on the geometry of the problem.
There is a note that the cylinder is defined only for x > 0, which may affect the limits for θ. The original poster expresses uncertainty about the limits for θ, indicating a need for further clarification.
ohlala191785
Find the volume of the solid that the cylinder r = acosθ cuts out of the sphere of radius a centered at the origin.
Cylindrical coordinates: x = rcosθ, y = rsinθ, z=z, r2 = x2+y2, tanθ = y/x
So I know that the equation for the sphere is x2+y2+z2=a2 since it's centered at the origin and has a radius of a. And I'm pretty sure the integrand is 1, so the integral should look like ∫∫∫rdzdrdθ. For the limits of z, I solved for z in the sphere equation and got z=±√a2-x2-y2, which in cylindrical coordinates is z=±√a2-r2. Therefore the limits of integration for z are -√a2-r2 and +√a2-r2.
The limits of r should be from 0 to a since a is the radius of the sphere. But I have no idea what the limits of θ are. Is it from 0 to 2π because it is a sphere?
Advice would be appreciated. Thanks.
The limits of your cylinder are different, and depend on r. You can draw a sketch of the r,θ-plane to see this.
If cylindrical coordinates do not work, try cartesian coordinates. The integration limits are easier there.
You can state your problem as a double integral, where the integrand is a function of the surface at point (x,y) - or (r,θ). Can you see that function?
Beware: as stated, the cylinder is defined only for x>0 (where cosθ>0).
Thanks for the advice everyone!
