Cylindrical glass boll (sealed, containing solvent) for RF detector
A developer in a high-field Nuclear Magnetic Resonance lab seeks assistance in creating a hermetically sealed glass micro capsule for an RF detecting circuit. The capsule must be a cylindrical glass structure, measuring 8.2 x 4.6 mm, filled with a deuterated solvent like acetone-d6. Challenges include cutting glass accurately without professional tools and sealing it without igniting flammable solvents. Suggestions include using a tapered tube with a ground stopper and seeking help from local school lab technicians skilled in glasswork. The discussion emphasizes the need for precise glass fitting techniques to achieve a vacuum-tight seal.
_maxim_
Dear all,
here's my first request for a little help (maybe also in finding the proper subforum...)
I'm working as developer and scientific consultant in a lab for Nuclear Magnetic Resonance at high field (> 21 Tesla), and I have to create a suitable probe for checking the stability of a wide-bore cryomagnet.
This will be done by a simple RF detecting circuit which pilots a coil, and the coil is wound around a micro boll containing a deuterated solvent (D2O, CDCl3, DMSO-d6 and so on). The RF circuit is already operative and capable to read out the very tiny signal which arises from deuterium inside the strong magnetic field ( as a quick reference, see http://www.cis.rit.edu/htbooks/nmr/chap-7/chap-7.htm#7.1" ).
Now, about my request.
I need to substitute the plastic micro boll with a soldered glass micro capsule, containing one of the deuterated solvent (i.e. Acetone-d6).
The main problem is to have a regular cylinder in glass, with max external dimensions L x D= 8.2 x 4.6 mm (Length x Diameter), fully filled with the liquid, and with its bases hermetically sealed.
Started cutting a NMR sample tube, I have no any laser precision device in my lab, hence the quality of the cutting is very poor. The subsequent problem is solder the glass with highly flammable solvents (i.e. acetone), but the risk could be reduced using cryogenic liquids (i.e. liquid nitrogen).
Do you have any idea for realizing this glass capsule?
Any idea would be greatly appreciated
All best
Max
It sounds like you need a professional glass worker.
As a suggestion, solder in a tapered tube with a mating (ground?) stopper, and seal it at the end while heat sinking the liquid.
Thanks Mike,
The point is that some solvent have quite low melting point and they vanish when one seals the cap.
Also, it seems there are no professional glass workers in my country. I asked to industries, but I am still waiting for an answer from a while.
I hope that physician people knows the way to build such a homemade device.
Cheers,
Max
P.S. maybe I have to move this question in another place?
Some School Lab Technicians are very competent glass workers. Do you have a local High School or College?
Good call on the technicians. Some college chem labs still have old techs that can work glass.
As for the technique, it's based upon sealing a tube with a tapered piston and then flowing them together at the far end from the fluid. I've seen some amazingly snug fits between glass parts that are ground to fit together.
I'm not certain how the glass was tapered, but I suspect that tube was ground out with a tapered copper rod. Diamond chips seed into the surface of copper well, and if you go slow, it will grind away at your glass.
Then follow with more diamond compound and the glass rod grinding to fit into the tapered tube.
The first vacuum tight seals were made this way, and by adding a bit of mercury to wet the seal.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
