The discussion revolves around finding a specific type of component for a prototype device, particularly a rotating cylinder switch with at least 7 positions. Participants explore terminology, potential sources, and related components, including rotary switches and stalk switches, while considering practical solutions for the prototype.
- Exploratory, Technical explanation, Debate/contested
- Mal is seeking a rotating cylinder switch with at least 7 positions for a prototype device, expressing uncertainty about the correct terminology to use for searching.
- One participant suggests that the component is still referred to as a rotary switch, specifically of a patented variety, and provides a patent link for reference.
- Another participant mentions "rotary switch dual concentric shafts" as relevant terminology and suggests that the component could be small enough to fit in a handle.
- There is a suggestion to search for "stalk switch," although Mal clarifies that this refers to the entire arm rather than just the ring.
- Mal considers the possibility of creating a custom solution or repurposing a stalk switch from a junkyard.
- One participant notes that in some cases, the actual switch may not be in the stalk but rather in the steering column, indicating a distinction in the design of different vehicles.
- Another participant explains that a stalk switch can control switches located in the steering column and suggests that purchasing a second-hand stalk may be more practical than disassembly.
- A suggestion is made to explore "slip rings" as an alternative component.
Participants do not reach a consensus on the terminology or the best approach to obtain the desired component. Multiple competing views on the definitions and applications of stalk switches and rotary switches remain present.
There are limitations in the discussion regarding the specific applications of the components mentioned and the potential for misunderstanding the mechanical relationships between different parts of the steering column and stalk switches.
This discussion may be useful for individuals working on prototype devices, particularly those interested in custom switch solutions or automotive components.
