Damped harmonic oscillator Diff. Eq. question
8 replies · 3K views · last reply
Dusty912
consider any damped harmonic oscillator equation
m(d2t/dt2 +bdy/dt +ky=0
a. show that a constant multiple of any solution is another solution
b. illustrate this fact using the equation
(d2t/dt2 +3dy/dt +2y=0
c. how many solutions to the equation do you get uf you use this observatiob along with duess-and-test method described in this section?
guess-and-test method. subbing est for y, and then solving for s value to obtain two solutions
now I know for (a) I am supposed to sub in ky(t) into the damped harmonic oscillator. but I am stuck from there. I am not really sure what kind of answer this question is looking for. Any help would be appreciated.
H i Dusty:
If you assume y(t) is a solution, what do you think "a constant multiple of any solution is another solution" means?
Hope this helps.
Regards,
Buzz
well I believe it means that if y(t) is a solution then ky(t) is also a solution. Where k is an arbitrary constant.
Im just not sure what the question is seeking as far as written work
Hi Dusty:
I would avoid using k as the "constant" used in the "constant multiple", since k appears in the equation. For example try cy(t) instead.
How would you show that cy(t) satisfies the DE?
Regards,
Buzz
Hi Dusty:
What do you get when you plug it in?
Regards,
Buzz
Hi Dusty:
Right. What do you get if you divide this equation by c? What does that tell you?
Regards,
Buzz
