Damped Oscillations: Does a Pendulum Ever Truly Stop?
  • Context: Undergrad
  • Thread starter Thread starter rugerts
    Damped Oscillations
The discussion revolves around whether a damped pendulum ever truly stops oscillating. Participants explore the implications of damping in both mathematical models and real-world scenarios, considering the effects of different types of damping and the definitions of "zero" oscillation.
  • Some participants assert that a pendulum in a vacuum will swing indefinitely, while questioning if a damped pendulum can ever truly reach a state of rest.
  • Mathematical models suggest that oscillations decrease asymptotically, but real-world factors introduce complexities that may prevent the pendulum from ever stopping completely.
  • There is a discussion about the definition of "zero" oscillation, with some suggesting that it is a matter of how small the oscillations must be to be considered negligible.
  • Participants note that the type of damping affects the outcome, with viscous damping potentially never allowing complete cessation of motion, while dry friction damping can bring the motion to rest.
  • One participant raises the fluctuation-dissipation theorem, suggesting that viscous damping could lead to fluctuations that might reverse motion temporarily.
  • Another viewpoint emphasizes the limitations of mathematical models, indicating that they may not fully capture the complexities of real-world behavior.
Participants express multiple competing views regarding whether a damped pendulum can truly stop oscillating, with no consensus reached on the definitions or implications of "zero" oscillation.
The discussion highlights limitations in definitions and assumptions regarding damping types and the nature of oscillations, as well as the potential for unresolved mathematical steps in modeling real-world behavior.
rugerts
A pendulum with no friction/resistance/damping (i.e. in a vacuum) will swing indefinitely.
Does a pendulum with damping effects ever truly stop oscillating? That is, does the graph tend to infinity or actually reach a value of 0, i.e. the equilibrium position?
Thanks for your time.
Mathematically, the oscillations decrease asymptotically.
But in real life, there are always nonlinearities, so yes it stops.
But also in real life, we have micro earthquakes, so no it doesn't.
It's just a matter of definition. How small do the oscillations get before you call them "zero?"
I think I see what you mean. If it's small enough (whatever that is), it will be effectively zero in the real world. In "math modeling world", it never really reaches 0. Like you said, though, if we're really dealing with non-linearities and the imperfectness of the real world, can we ever say it actually reaches zero? Or is this just not measurable and therefore an invalid (and more philosophical) question?
rugerts said:
Ican we ever say it actually reaches zero?
Don't you see? This is not a math or a technical question but rather a language question. How do you define actually zero?
How small? Lasting for how long?
In the case of a damped pendulum we would typically consider linear damping -- a retarding force that is proportional to the pendulum's velocity. With small (under-damped) linear dampening the motion of the pendulum will turn out to follow a sine wave multiplied by a decreasing exponential.
e.g. ##x(t) = cos(t) e^{-t}## (with constants added to get the right phase, frequency and decay rate).
You can find more than you may have wanted to know here: http://hyperphysics.phy-astr.gsu.edu/hbase/oscda.html
Zero = no movement
It all depends upon the kind of damping present. Viscous damping will never totally stop the motion, but dry friction (Coulomb) damping will bring the motion completely to rest.
Is it not a consequence of the fluctuation-dissipation theorem that viscous damping will necessarily be accompanied by fluctuations and that these will cause the motion to reverse (at least for an instant) after a finite time?
This is an example of how the real world is infinitely more complex than any physics you'll ever learn can explain fully. Everything you learn is approximation. So it's best you accept those limitations; there's plenty left for you with which to be challenged!
Of course it does.
The graph is part of the model used to describe the behavior of the pendulum. If your model involves a damping factor proportional to the speed then that model will predict an infinite amount of time for the pendulum to stop. By the way, at some point the velocity and the position predicted by the model will need to be known simultaneously with an uncertainty that's less than the Heisenberg Uncertainty. In other words, the model fails outside of its limits of validity.
  • · Replies 131 ·
  • · Replies 17 ·
