What are the Max and Min Values for Tide Height?
  • Thread starter Thread starter Veronica_Oles
    Data Modeling
The sinusoidal function h(t) = 5 sin(30(t-5)) + 7 models tide height, with a maximum of 12 meters and a minimum of 2 meters. High tide occurs when the sine function reaches its maximum, specifically at t = 5.5 hours after midnight, while low tide occurs at t = 11.5 hours. The depth of water at 9:00 AM (t = 9) is calculated to be 11.3 meters. Understanding the vertical shift and amplitude of the function is crucial for determining these values.
Veronica_Oles
The height, h, in metres, of the tide in a given location on a given day at t hours after midnight can be modeled using the sinusoidal function h(t)= 5 sin 30 (t-5) + 7
(A) find max and min value for depth of water.
(B) what time is high tide? What time is low tide?
(C) what is the depth of the water at 9:00am?
(A) The maximum would be 12 because 5 + 7. The minimum would be 2 because 7-5. However when it comes to questions b and c I have no idea what to do or where to even begin.
(A) The maximum would be 12 because 5 + 7. The minimum would be 2 because 7-5.However when it comes to questions b and c I have no idea what to do or where to even begin.
I've figured out c just really stuck on b.
What process did you use to get the answers to (A) ?
... and (C) ?
I added the a value and the c value to obtain my maximum and I subtracted my c and a value to get my minimum.
That's fine.
Why does that work?
By the way, what is the answer to (C) ?
SammyS said:
That's fine.
Why does that work?
The answer to c is 11.3 because I just substitute 9 for t in the equation.
That's fine.
Why does that work?
SammyS said:
That's fine.
Why does that work?
It works because
SammyS said:
That's fine.
Why does that work?
It works because the vertical shift is constant and the midline. Therefore you add or subtract the amplitude from it to get your answer.
Veronica_Oles said:
It works because
What is shifted vertically?
How is this related to the sine function?
The height (m) gets shifted vertically?
What function is it that's shifted vertically?
Maybe I should have asked something more obvious.
Can you solve ##\ 5 \sin (30 (t-5)) + 7 =12 \ ## for ##\ t\ ## ?
yes you can. Wouldn't the answer be 5.5?
What are the units of the coefficient, 30 ?
Isn't the 30
not sure but is degrees? 30 is k value
Veronica_Oles said:
Isn't the 30
I have figured it out I realized I calculated something incorrectly.
Veronica_Oles said:
Isn't the 30
Right. Well then, actually it's 30 degrees per hour .
sin(θ) is a minimum (-1) or maximum (+1) at θ = -90° or 90° respectively ... of course ± integer multiples of 360° .
