Can a Firewire Output Be Split and Converted to NTSC Format?
  • Thread starter Thread starter Firefox123
    Data
A user seeks a solution to split a FireWire (1394) output from a camera into two outputs: one for a monitor and another for converting to an analog NTSC video signal. The discussion suggests checking if the camera's AV output is active while using FireWire, as it may already provide the NTSC signal. It is noted that finding a specific device to split and convert the signal may be challenging and potentially expensive. A recommendation is made to consider the Dazzle DV Bridge, which supports both FireWire and NTSC outputs.
Firefox123
Hello all...
Suppose I have a camera that is recording data and then sending it over firewire (1394) to a monitor and displaying VGA (or DVI).
What I want to do is split the firewire into two outputs…
1. The normal fire wire output that gets sent to the monitor
2. An analog video signal (NTSC format) that we will eventually convert
into a fiber signal.
Is there an existing piece of hardware that will perform the function of splitting the firewire output and convert one output to NTSC format? If there is then I am having a difficult time locating it.
Does anyone know of any way to do this?
Russ
Computer science news on Phys.org
You might try seeing if the cameras AV output is active while the computer is driving the firewire connection.
The camera AV output would be your NTSC signal.
To do it the way you are asking is probably possible, but its not likely you will find something that does it.
If I understand you correctly there is a device that can do this. I just need to speak with my friend and ask what it is called. I remember it being very expensive...
I agree with NoTime. You're really barking up the wrong tree with trying to convert FireWire (digital, MPG-compressed video) into NTSC (analog). The camera probably already has both outputs; just use both.
- Warren
Thread 'Urgent: Physically repair - or bypass - power button on Asus laptop'
Asus Vivobook S14 flip. The power button is wrecked. Unable to turn it on AT ALL. We can get into how and why it got wrecked later, but suffice to say a kitchen knife was involved: These buttons do want to NOT come off, not like other lappies, where they can snap in and out. And they sure don't go back on. So, in the absence of a longer-term solution that might involve a replacement, is there any way I can activate the power button, like with a paperclip or wire or something? It looks...
In my discussions elsewhere, I've noticed a lot of disagreement regarding AI. A question that comes up is, "Is AI hype?" Unfortunately, when this question is asked, the one asking, as far as I can tell, may mean one of three things which can lead to lots of confusion. I'll list them out now for clarity. 1. Can AI do everything a human can do and how close are we to that? 2. Are corporations and governments using the promise of AI to gain more power for themselves? 3. Are AI and transhumans...
