DC Motor Efficiency: Does It Change With Voltage?
The efficiency of a DC motor is not constant and changes with applied voltage and current. The formula for efficiency, defined as (V*I)/(Torque*velocity), indicates that as torque and current vary, efficiency also fluctuates. The relationship between torque and current is described by T=(motor constant*current), and efficiency impacts motor performance significantly. Factors such as magnetic field saturation and heat effects on conductance further contribute to the non-linear relationship between voltage, current, and efficiency.
  • Understanding of DC motor principles and operation
  • Familiarity with electrical power equations
  • Knowledge of torque and its relationship with current
  • Basic concepts of magnetic field saturation and thermal effects
  • Research the impact of voltage variations on DC motor efficiency
  • Explore the effects of heat on electrical conductance in motors
  • Study the relationship between torque and current in greater detail
  • Learn about methods to optimize DC motor performance under varying loads
Electrical engineers, motor control specialists, and anyone involved in optimizing the performance and efficiency of DC motors.
mawad
Hello,
I would like to know if the motor efficiency is changing with respect to applied voltage or it doesn't change. What I do mean. The efficiency=(V*I)/(Torque*velocity) and the power losses= I^2*R. Can I say that
mechanical power ( Torque*speed)=V*I-I^2*R
If so, can I say that the efficiency is not constant with torque and current changing?
Also, the torque is function in current
T=(motor constant*current)=km*I
What about the efficiency? Does the efficiency effect on the motor performance? Can I say
T=efficiency*motor constant*current
Many thanks
the torque and velocity want to track with the voltage/current in a linear fashion but the level of saturation in the mag field and the effect of heat on conductance will insure that they cannot track linearly so, as you have surmised, the efficiency will change with
voltage/current.
