DC to DC circuit for automotive relay - 5v to 12v
A user seeks guidance on activating a 12V DC relay using a 5V power source from an oil pressure switch in an old truck. The discussion highlights the possibility of using a 5V relay to control the 12V relay, emphasizing the need to determine the coil current for proper activation. Suggestions include using a transistor circuit to amplify the 5V signal and incorporating a flyback diode to protect against voltage spikes. Participants recommend specific components, such as a 2N3415 transistor and a 1N4004 diode, while also discussing the importance of calculating base resistor values. The conversation also touches on alternative solutions like using a MOSFET for switching applications.
LUI-G
Greetings E.E. Gurus!
I'm a noobie in need of your guidance!
Here's the situation:
I have a 5V DC, 0.25 amp (1.25W ?) power source from an oil pressure switch wire on an old truck that is activated only when the engine is running.
My goal is to activate a 12V DC, 2.5 amp, 30/40W relay, which will be activated continuously while the engine is running.
I have yet to take a course in electronics, and will do so in the future... but right now I have this dilemma...
I've done a bunch of reading online but have not had any luck finding the info I need to build this simple circuit...
Thank you all for your replies!
Welcome to the PF.
It sounds like you can use your 5V signal to power a 5V relay, and the output of the 5V relay can drive the 12V relay. What is the required coil current for the 12V relay? The 2.5A number is the allowed output current, I would think, and not the coil current.
Hmmmm... I'm not sure... How can I find out? I have the relay...
Does it have a manufacturer name and part number? You can use that to find the datasheet on the Internet usually...
Here's a pic. thanks for your help!
I'll do some research on that and post it ASAP... thanks!
Hmm. My googling is not showing APO as a relay brand so far...
Are there any other markings? Where did you get the relay?
I found a similar one on ebay. I messaged the seller to see if he has a data sheet...
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=370478844324
so according to the seller, there's no data sheet for the relay...
How can I test the relay to see what the minimum current to activate the coil would be? Would a variable resistor or something, help?
You can just put 12V across the coil and measure the current.
Berkeman, I appreciate you replying and helping me out!
So I ran a bench test with a variable AC/DC power supply and found that the relay did not switch at 5.75V, 1.7A, but DID switch ON at 7.65V, 1.65A
Couldn't a simple transistor circuit be made to amplify 5V, 0.25A ?
I found a transistor circuit example here, but I can't follow it too well... It doesn't allow me to adjust the base current...
http://www.bcae1.com/transres.htmIf so, what exact components would I need?
I read somewhere I should start with a diode to prevent any current leaking back to my power source and then use a resistor in series with the base, and add resistors to the emitter and collector, but I don't know what sizes, etc.
Also, a diode should be attached across the relay coil to prevent any voltage spikes when it's turned off, but I don't know what size...
Yes, you should be able to use the 5V source to drive a transistor. Connect one side of the relay coil to +12 and the other coil terminal to the collector of the transistor. Put the emitter of the transistor to ground.
The sensor's 5V ouput would go to the base of the transistor through an appropriate resistor. Don't forget a flyback diode across the relay coil to protect the transistor.
Awesome! Thanks mdjensen22! Can you tell me which transistor and diode to use?
The transistor is dependent upon the current of the relay coil for energization. You need to measure this or find a datasheet for the relay. I assume something like a 2N3415 should work.
For the diode, I typically use a 1N4004, or a 1N4148 depending on the design.
Your base resistor will probably be something like a 1K or less (470 maybe?). This is calculated based on the collector current (relay coil current) and the current gain of the transistor that is selected (Hfe).
berkman; similar question. I have a set of auxillary lights on my motorcycle, I'm attempting to turn them on using the flash to pass switch. I have a relay and existing wiring in the head lamp housing, but the relay is momentary. Is there a switch I could put inline, or another type relay, that would stay on, then turn off with the next flash to pass input? Just joined the site while searching for a switch. Thank you in advance.
Why not dump the 12V relay completely and just replace it with a suitable MOSFET? You can then switch the MOSEFT with the 5V supply connected directly onto the FET's gate.
cmb, thank you for the reply. However, I don't have a 5v, it's 12v. I'm trying to use the flash to pass, which sends a 12v signal, to turn on the auxillary lights on my motorcycle. A latching relay would work if I can find one. I googled a moseft but not tech savy enough to understand how this would work.
Are you trying to wire into your flasher relays?
Those typically are not relays in the conventional sense (coil and contacts) - flasher relays are typically just bimetallic contacts that heat when the current passes through them and then they open until they cool at which point the cycle repeats itself.
http://auto.howstuffworks.com/turn-signal2.htm
mdjenson22; no, fortunately a little more savy than that, but not by much;o) My bike also has an empty 12v, ground, and plug for a standard three prong headlamp for the U.K. It also has a flash to pass function. I can use the empty 12v and ground to drive the lights through a relay, and the flash to pass function from the high beam side of the empty UK socket, obviously a standard relay would only power the lights when powered, but a latching relay will stay in the last keyed position, that's what I'm trying to find.
I found one on line, but after reading the review it stated that it was infact only a standard relay.
search Digikey or Farnell - both sell latching relays.
