De Broglie equation and black holes
The De Broglie equation, which describes the wave-like nature of particles, does apply to black holes, although the resulting wavelength is negligible in practical terms. The discussion suggests that if black holes could be observed over an extremely long timescale, they might produce interference patterns similar to those seen in double slit experiments, though this is not a significant consideration. There is debate about whether space-time flows or if matter and photons move within it, with differing views on the implications of black holes on space-time dynamics. The conversation also touches on the potential for reversing the photoelectric effect in relation to black holes and antimatter. Overall, the complexities of quantum mechanics and general relativity in the context of black holes present intriguing theoretical possibilities.
bassplayer142
Does this apply to a black hole? What would be the consequences of it? Thanks
Astronomy news on Phys.org
I assume you are talking about the De Broglie wavelength describing the wave-like nature of any object.
\lambda = \frac{h}{p} = \frac {h}{\gamma mv} = \frac {h}{mv} \sqrt{1 - \frac{v^2}{c^2}}
The is a Quantum Mechanical description. Yes it applies to black holes, yet in practice the wavelength is so small as to be pointless. Note that the wavelength and frequency is defined as probability waves. Getting into interpretations is probably too problematic here. The consequences is that if you had a few trillion trillion times longer than the life of the Universe you could get black holes produce an interference pattern in a double slit experiment. Not a consequence worth thinking much about.
Ok, we will try it here: Gh/CC is the Universal flow constant, so what does that say about black holes?
ok sammy, for me it means that space-time is flowing and it accelerates due to black holes presence. What do you think about that ?
I do not think that space-time flows, rather photons and other matter flow in space-time. If E=hn does -E=-hn ie. dE=hdn? For a black hole we can use Albert's photo-electric effect but reverse it (Sammy's electro-photic effect) and use anti-matter, then we should get photons going backwards in time ie. going back to the source and let the source be the black hole. This is a linear model like simple relativity, but we could also use GR for a gravitational model.
Gh/CC is the space/time constant; the units: dxdydz/dt; this is the first derivative of space with respect to time and it is constant.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
