De Broglie Wavelenght of a 5.5Mev
The de Broglie wavelength of a 5.5 MeV alpha particle is calculated using the formula λ = h/p, with p derived from the classical momentum equation. The calculation shows that the wavelength is approximately 6 x 10^-15 m. This value is smaller than the diameter of the Americium-241 nucleus, which is 1.6 x 10^-14 m. The findings suggest that the alpha particle's wavelength could exist within the nucleus. Therefore, it is feasible for the alpha particle to be contained inside the Am-241 nucleus.
diegoarmando
Calculate the de Broglie wavelenght of a 5.5 Mev alpha particle emitted from Am (241) nucleus, could this particle exist with inside the Am (241) nucleus (diameter = 1.6x10^-14m)?
the wavelenght:
Lambda=h/p = (hc) / (sqrt[2mc^2)xeV)
= 1240 / sqrt(2x3727.38x10^6x5.5x20^6)
Well...
The alpha particle is nonrelativistic since KE/mc^2 = 10^-3, so you can use the classical formula for momentum p = sqrt(2mKE).
Use this momentum to find the deBroglie wavelength.
Use the uncertainty principle to find out the spatial resolution of a particle with this momentum.
(hands wave around)
x ~= h/(4*pi*p)
Is this x larger than the diameter of the nucleus?
I find 6x10^-15 m for lambda, so the diameter of Am is 1.6x10^-14, so the wave length is less than the diameter, is that mean the wavelength can be exist inside the Am nucleus?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
