Death of a car battery and related issues
- Topic: Automotive
- Thread starter Wrichik Basu
- Start date
- Tags
- Battery Car Car battery Death Issues
39 replies · 7K views
mic*
- 99
- 11
New generation stop-start features are engineered somewhat differently to older lead-acid systems. For example, they may contain a supercapacitor (very low impedance = very fast charging) to support a sealed gel-electrolye battery.CWatters said:Indeed. My car turns off the engine automatically at stops. So on the school run it restarts about a dozen times in 30 mins.
Although 30min minimum charge for one start is very conservative even for lead-acid, I would not try starting an unsupported lead-acid battery once every 30sec with only idling between. It WILL die faster.
OmCheeto
- 3,666
Not to mention your starter. I did the experiment on my last vehicle, and my starter failed within a week.mic* said:New generation stop-start features are engineered somewhat differently to older lead-acid systems. For example, they may contain a supercapacitor (very low impedance = very fast charging) to support a sealed gel-electrolye battery.
- 2,188
- 2,694
Even if I keep the issue of the battery aside based on what @mic* said, doesn't that consume more fuel? I generally had the idea that an engine in good condition, if kept in idling state at traffic signals, consumes less fuel than what it would have consumed when switched off and turned on again and again (I assume that air conditioners, heaters and defoggers are all switched off).CWatters said:Indeed. My car turns off the engine automatically at stops. So on the school run it restarts about a dozen times in 30 mins.
mic*
- 99
- 11
In short, no.Wrichik Basu said:Even if I keep the issue of the battery aside based on what @mic* said, doesn't that consume more fuel? I generally had the idea that an engine in good condition, if kept in idling state at traffic signals, consumes less fuel than what it would have consumed when switched off and turned on again and again (I assume that air conditioners, heaters and defoggers are all switched off).
Maybe in the past it could not have worked so well, but electronic fuelling and engine sensing is relatively precise these days. The engine will be warm, so there will be no "cold start" enrichment. And the engine knows exactly where it is so you generally find they fire immediately, rather than needing that extra turn of the crank before running. They fire up so quick that by the time your foot has moved from the brake to the accelerator, your engine is already running again.
Homework Helper
- 2,324
My understanding is that auto start stop does or can discharge the battery deeper than otherwise but they have a BMS system that turns off the auto start stop mode if it gets discharged too much. They may also use a slightly larger battery than on comparable cars without auto start stop. Don't think the battery is supported with a super cap, at least not on my car.
mic*
- 99
- 11
Larger bttery units seem to be another approach. SC's are rated at >500,000 cycles so they are not considered a servicable part. They will outlast your steering wheel.CWatters said:My understanding is that auto start stop does or can discharge the battery deeper than otherwise but they have a BMS system that turns off the auto start stop mode if it gets discharged too much. They may also use a slightly larger battery than on comparable cars without auto start stop. Don't think the battery is supported with a super cap, at least not on my car.
Education Advisor
- 3,212
- 3,841
Wrichik Basu said:We have a Toyota Etios Liva, four years old, petrol variant. ... Our car is not used much. Usually on an average, it is driven for around 14km per month.
Is this number (14km per month) correct? The four-year old car has 670 km (~400 miles)? At the advertised mileage (about 20 km per liter) you have burned around 34 liters (9 gallons, US) in the past four years?
I have had vehicles with low use like this (not cars, but motorcycles and scooters) and I would expect all kinds of problems: gasoline turned to sludge, clogged carburetor, dead battery, flat spots on the tires, mice eating the wiring, etc. If the use is really this low I would advise either drive it more, or sell it and use taxis to get around.
- 2,188
- 2,694
Well, I didn't think of such detailed calculations. The average value was of 2018. In the previous years, it has traveled quite a distance. The odometer reading currently is a little greater than 5000km.gmax137 said:Is this number (14km per month) correct? The four-year old car has 670 km (~400 miles)? At the advertised mileage (about 20 km per liter) you have burned around 34 liters (9 gallons, US) in the past four years
Automotive
Jumpstarting a dead car battery
- lucas_
- · Replies 7 ·
- Mechanical Engineering
- Replies
- 7
Automotive
How long is too long for a dead car battery
- John1397
- · Replies 12 ·
- Replies
- 12
- rprastein
- · Replies 10 ·
- Electrical Engineering
- Replies
- 10
- paradoxlost
- · Replies 21 ·
- Replies
- 21
- taz24
- · Replies 5 ·
- Replies
- 5
Automotive
How long to charge Dead Car Battery
- russ_watters
- · Replies 41 ·
- Replies
- 41
- sevensages
- · Replies 54 ·
- Replies
- 54
- Cyclonus
- · Replies 5 ·
- Replies
- 5
- DagmaarUlereich
- · Replies 6 ·
- Replies
- 6
- karabiner98k
- · Replies 21 ·
- Replies
- 21
