Debunking Time Travel Speculations: The Truth Behind Going Back in Time
In summary, time travel seems to be an impossibility because you would have to undo all the actions you've taken in order to exist in two separate states of time.
sciencectn
From what I've seen, most speculations of time travel seem to say that when you go back in time, everything else around you returns to an earlier state that it used to be. For example, if you stand outside your house and go back in time, the house will "un-build" itself and there will be nothing there.
However, what it seems like is that everything else AROUND you is going back in time, not you. If it were just you that went back in time, you would simply get younger.
But here's what I don't get if this is true. Let's say you went back one year. You would supposedly get one year younger. However, during that year, you interacted with the outside universe in a number of ways; you breathed and modified air molecules, you ate food, and you manipulated objects (like driving a car, picking up things, etc.). In addition, in order for the universe and you to exist in two separate states of time, the matter that you are composed of would have to be put on "hold", because if everything else around you went back in time, a certain portion of matter would disappear. If it were just you that went back in time, all those ways in which you interacted with the outside world would have to be undone, but this would cause the entire universe and all it's contents to shift back in time in equal amounts, thus creating no net time travel effect at all.
If this is true, then any attempt to go back in time will require an almost infinite amount of energy (since you are modifying the state of everything) and it will appear that absolutely nothing has happened.
I don't see how time travel is even remotely possible.
Hi sciencectn and welcome to the forum.
Just like to say I think you raised some really pertinent questions. Have to say also that I think you've hit the nail on the head when you said that time travel is not even remotely possible.
I am pretty sure that is the idea of entropy or at least the result of it. It has away of saying time goes one way. And with irreversible processes, you have to put in more energy to get them back to their original state. Pretty cool idea.
What you're saying does make sense. Essentially, time's arrow is identified with entropy and vice-versa...its not so much that time travel is impossible...I think its more along the lines of having to modify our outlook on the behavior of energy (if time was flexible).
if someone were to go 'back in time', then they would 'remember' their future in exactly the same way we remember our past.
The person going back in time in this regard would be fascinated at the prospect of 'remembering' a past event, such as when he turned 16, drove a car for the first time; dated his GF for the first time. Such concepts of 'memory' that are common to us would fascinate the imagination of the guy who's going backwards in time.
I've been an SF fan for over 40 years, and I honestly think that the OP brings up aspects of time travel that I haven't seen explored before. (At least, not in that particular form.) Good job, Sciencectn.
Hi, sciencectn, welcome to PF.
I like your view. You raised points which I have not heard or thought about before.
sciencectn, if you haven't read the book "Time Travel in Einstein's Universe" by J. Richard Gott, you might consider looking at it - sounds like you might be interested. He brings up some similar points in the section on djinni (objects with closed cyclical worldlines), and there are a bunch of other more or less wacky ideas about time travel.
I'd like to encourage everyone to take a look at the PF rules on Overly Speculative Posts. Neither time travel nor souls are observed or can be studied scientifically.
Doesn't QM say that atoms will have only one history .
But based on your previous concern, aren't we actually traveling through time right now, at the fixed rate of 1 second per second?
As far as I know, the many worlds interpretation of QM actually states that particles have infinitely many histories and infinitely many futures.
my comment has been removed because I violated the speculative rules. That is interesting because time travel is totally speculative. Anyway, I am not a physicist and I don't think I will be back here. Good luck with the moderator of this forum (ZapperZ) who confess being a dork in his profile. Remove me forever if you want and stop the incomming of new ideas "dork"
That statement is quite unnecessary and rude, Pyocote. Note that the rule applies to overly speculative posts. Every scientist speculates, but does so within the bounds of what is accepted as physically possible. I didn't see the post that you refer to, but it must have violated that aspect of the subject to be deleted.
my mistake
Incorrect. We are actually traveling forwards in time at a rate slightly smaller than that due to gravitational time dilation. See [A HREF=[PLAIN]http://en.wikipedia.org/wiki/Geocentric_Coordinate_Time]Geocentric[/PLAIN] Coordinate Time[/A]. Perhaps we should say that backwards time travel (with this method) is not remotely possible.
If somebody in future discovered the time machine, why didn't they come back in time [to the present] to visit us?
Because they haven't built the time machine yet. GR time machines can only take you back to a time after the time machine was built.
how do you know they haven't :cool:
If you say they haven't discover the time machine. Is that means time machine is not in existence? This is because far in future there should be an existence of time machine, this is what been predicted by the physicist [in the present time]. This only could be a myth in my point of view. I'm just giving my opinion, so take it easy.
Thank you.
I don't understand why time travel is impossible. Time travel is possible and some human beings already went into the future.
It is calculated that astronaut who spent a great deal of time orbiting the Earth in the international space station would be traveling to the future by a very minuscule amount. I do not remember the exact amount but it was smaller than one hundredth of a millisecond or something. He or she would be that much younger as they arrive back on earth. Imagine them keep on going faster and faster around the earth. The faster you go, the slower the time passes for you. There is your time travel to the future.
Time travel to the past is highly disregarded because of many physical and philosophical arguments.
Related to Debunking Time Travel Speculations: The Truth Behind Going Back in Time
1. Can we really go back in time?
Currently, there is no scientific evidence or technology that supports the possibility of physically going back in time. While some theories, such as the concept of wormholes, suggest the existence of time travel, they are purely speculative and have not been proven.
2. What about time travel in science fiction?
Time travel is a popular theme in science fiction, but it is important to remember that it is just that - fiction. The concept of time travel is often used as a plot device and may involve unrealistic or scientifically impossible scenarios.
3. Is time travel possible in the future?
While it is impossible to definitively say whether time travel will ever be possible, current scientific understanding suggests that it is highly unlikely. Time travel would require a complete understanding of the complex workings of time and space, which is still a mystery to scientists.
4. What about the concept of time dilation?
Time dilation, a concept from Einstein's theory of relativity, does allow for time to pass at different rates for objects moving at different speeds. However, this does not equate to time travel in the sense of physically going back in time.
5. Are there any potential consequences of time travel?
The idea of going back in time and changing the course of history is a common theme in time travel stories. However, according to the laws of physics, changing the past would create paradoxes and could potentially lead to catastrophic consequences. Thus, even if time travel were possible, it is widely believed that it would be dangerous to attempt it.
  • Other Physics Topics
  • Science Fiction and Fantasy Media
