Decay chain of radioactive isotopes
beee
How can I efficiently calculate the amount of material decayed after a specific time in a two-step decay chain?
In my specific example, I have 56Ni -> 56Co -> 56Fe. The half life of the first process is 6.1 days, the second - 77.7 days. How can I accurately calculate the amount of 56Fe that was created after a certain time from a given quantity of 56Ni? Is there a formula for "effective half life" of such a decay, in particular when the objective is to calculate the amount of final substance created after time t, as opposed to the amount of initial substance remaining?
This problem can be solved using analytical approach since it's a simple linear decay chain(without branching, the coefficients are distinct), I recommand you the paper published by Batman(Solution of a system of differential equations occurring in the theory of radioactive transformations) 100 years ago(the equation that govern this problem is also known as Batman equation).
For a more general problem(no distinction is needed for coefficients), you can find solution from Jerzy Cetnar's work("General solution of Bateman equations for nuclear transmutations").
Hope that will help^_^
Thank you, Bateman equations are exactly what I was looking for!
Toponium is a hadron which is the bound state of a valance top quark and a valance antitop quark. Oversimplified presentations often state that top quarks don't form hadrons, because they decay to bottom quarks extremely rapidly after they are created, leaving no time to form a hadron. And, the vast majority of the time, this is true. But, the lifetime of a top quark is only an average lifetime. Sometimes it decays faster and sometimes it decays slower. In the highly improbable case that...
I'm following this paper by Kitaev on SL(2,R) representations and I'm having a problem in the normalization of the continuous eigenfunctions (eqs. (67)-(70)), which satisfy \langle f_s | f_{s'} \rangle = \int_{0}^{1} \frac{2}{(1-u)^2} f_s(u)^* f_{s'}(u) \, du. \tag{67} The singular contribution of the integral arises at the endpoint u=1 of the integral, and in the limit u \to 1, the function f_s(u) takes on the form f_s(u) \approx a_s (1-u)^{1/2 + i s} + a_s^* (1-u)^{1/2 - i s}. \tag{70}...
