Deciding batteries for my circuit
  • Thread starter Thread starter bremenfallturm
    Circuit Leds
bremenfallturm
TL;DR
My question is basically if someone can confirm that my pessimistic power consumption calculations are done correctly (I have rudimentary electronics knowledge), so I can realize that I should reconsider my design :)
Hi!
I am trying to create a circuit which can individually turn on and control 12 LEDs from 4 pins, since I am trying to adapt it to a tiny microcontroller (the Attiny85, which does not have enough pins to drive the LEDs)
For this, I am using a method called Charlieplexing. You can for example read about how it works on Wikipedia, which has a better explanation than what I can come up with. I have posted about this project in another thread, see here: https://www.physicsforums.com/threads/charlieplexing-leds-have-different-brightness.1078255
The schematics I am using can be found below, where JP1-4 are GPIOs on the microcontroller I will be using:
My plan is to use Charlieplexing to (in the worst case), light up all of the 12 LEDs, with the last one blinking, like this:
To make the LEDs appear to be all on at the same time, I'll basically have to pulse through 12 different microcontroller pin states to light each of the individual LEDs very quickly.
I originally wanted to drive my microcontroller from a CR2032 battery, but I realize that it might not be enough to power it for a long time... (this is going to be part of a battery-powered bar-chart timer which I'd probably be using for 13 hours a day, so...)
Each LED is when lit, basically equivalent to this circuit
(note that 300Ohm equivalent resistance was an accident from my side - when prototyping I used 150Ohm resistors instead of my intended 75Ohms. But the LEDs are as bright as I want...)
I measured my new CR2032 battery to about 3.2 volts. My LED is rated ##V_f=2V## typical.
##V_R=3.2-2=1.2V##
If ##R=300\Omega## I am feeding through ##I=\frac{1.2}{300}=4\text{mA}## over each of the LEDs.
Making the pessimistic assumption that all LEDs are on simultaneously, the LEDs draw the total current ##4\cdot 12=48mA##. My CR2032 is rated at 220mAh.
The capacity over the current:
\frac{220\text{mAh}}{48\text{mA}}\approx 4\text{ hours }34\text{ minutes}
If I make the pessimistic assumption that all LEDs are on simultaneously, are my calculations correct? (If so I shall look for another alternative...)
The "all LEDs on" assumption is impossible. Where in your calculations do you allow for the duty cycle of the LEDs?
Why do you multiply the LED current by 12, if only one is on at the time?
I would expect to find some way to increase the duty cycle to about 1/6 by considering some combination of on times, but I see no way to make it 1/1.
The "thermometer display" uses more power with LEDs, because many LEDs must be operated sometimes.
Alright, I see your point. Am I correctly understanding that my duty cycle would be ##\frac 1 {12}##? What I currently do is that I cycle between all 12 pin states with a delay of 1ms between each of them. This would mean that one LED is on for ##\frac{1 \text{ms (each LED's individual ontime)}}{12\text{ ms (full cycle)}}=\frac 1 {12}##, right?
______
I am unsure where to continue from this, but to be more specific, let me tell you where I am stuck.
If I got my duty cycle correct, I'm not sure where to apply it. If I only consider one LED at a time (i.e. not multiplying the final result by 12), I don't see where to apply the duty cycle. One LED could always be considered to be on at each moment in time, right?
So that would mean that I'd simply not multiply by 12 for the total current draw; the total current draw at each point in time be ##4\text{mA}## and I'd instead have ##\frac{220\text{ mAh}}{4\text{ mA}}## which would give 55 hours of running time.
Or where does the duty cycle come in?
You would "... simply not multiply by 12 for the total current draw ... ".
The peak current at any time, (during the 12 ms scan), would be only one LED current. 4 mA.
Since, on average, 6 of the 12 LEDs would be turned on during the cycle, the average current while operating would be ( 6 / 12 ) * 4 mA = 2 mA. That can be used to estimate battery life.
In your code, you would allocate 1 ms for each LED, if it was on you would turn it on, if it was off, you would not turn it on. The result would be that LED brightness would be consistent, independent of the number of off LEDs, since the cycle would repeat every 12 ms.
