Deciphering Mouser's Line/Load Regulation Classifications?
  • Thread starter Thread starter TheLaw
    Regulation
The discussion focuses on selecting power management ICs for a dual rail power supply capable of +/-12V and +/-5V. The user seeks clarification on line and load regulation measurements, which are critical for ensuring stable output voltage. Line regulation measures output voltage variation with input voltage changes, while load regulation assesses output voltage variation with load current changes. Lower values for both line and load regulation are generally preferred for stability, but comparisons should be made under specific conditions to avoid misleading conclusions. Understanding these parameters is essential for effective component selection in power supply design.
TheLaw
Am I the only person who gets really nitty-gritty about component selection? Well probably not, but I am having a bit of trouble picking out my power management ICs.
I am building a dual rail power supply. I guess you could call it that. It can do +/-12V and +/- 5V. It may be useful somewhere down the line.
So, the most I have every really done in electronics is a AA battery source, a cap, resistor, and maybe an LED or lightbulb. I am looking to change my ways here.
But regarding the ICs. I need a 7812, 7912, 7805, and 7905.
Here's a link to what I am talking about:
http://www.mouser.com/Semiconductors/Power-Management-ICs/Linear-Regulators-Standard/_/N-5cg9g?P=1z0w8gzZ1yzvdtq&Keyword=7812&FS=True
Note Line Regulation and Load Regulation.
I didn't know either were measured in such a matter. I thought it was a percent or fraction or something.
In this case, would it be better to go for one with a higher or lower Load/Line Regulation for a more stable supply?
Thanks.
Line regulation is defined as the variation in output voltage for a specified variation in input voltage.
Load regulation is defined as the variation in output voltage for a specified variation in load current.
Generally lower values are preferable for both of these, but be aware that each will be measured under specific conditions (voltage/current variations) with a specific test circuit (input and output capacitors) and so direct comparisons of different devices could potentially be misleading.
Thank you very much. I wasn't sure exactly what was going on there.
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
