Decompositoin of f(x) in Legendre polynomials
Apteronotus
Hi,
In Wikipedia it's stated that
Legendre polynomials are useful in expanding functions like
<br /> \frac{1}{\sqrt{1 + \eta^{2} - 2\eta x}} = \sum_{k=0}^{\infty} \eta^{k} P_{k}(x)
Unfortunately, I am failing to see how this can be true. Is there a way of showing this?
I know that Legendre polynomials form an orthonormal set, and so given any function, we should be able to decompose it into a 'linear combination' of these polynomials. But what form does this decomposition take?
Mathematics news on Phys.org
If ui is an orthonormal basis for a vector space and v is any vector in that space, then v can be written as v= \sum a_i u_i. Taking the inner product of v with any member of the basis, say uk gives &lt;u_k, v&gt;= &lt;u_k, \sum a_iu_i&gt;= \sum a_i&lt;u_k, u_i&gt;= a_k because <uk, uk>= 1 while <u_k, u_i>=0 for any value of i other than k. That is, you can find the coefficient of Pk by taking the innerproduct (defined as an integral) of the function with Pk. According to Wikipedia (yes, I had to look it up!) the coefficients of the function f(x) for the Legendre polynomials is
&lt;f, P_k&gt;= \frac{1}{2n+1}\int_0^1 f(x)P_k(x)dx
HallsofIvy
Thank you very much for your explanation. I understand now, the reasoning behind the equation.
On a technical note,
1. where does the term \frac{1}{2n+1}in front of the integral come from?&lt;br /&gt; 2. why do we integrate from 0-1?&lt;br /&gt; &lt;br /&gt; and lastly,&lt;br /&gt; 3. would the value of /etain our function \frac{1}{\sqrt{1 + \eta^{2} - 2\eta x}} play any role in our calculation of Pn&amp;amp;amp;amp;amp;#039;s coefficients?
Ok, so I think I have the answer to my first two questions and for anyone reading this thread, I'm going to try to answer them.
1.
The term <br /> \frac{1}{2n+1}<br />
in front of the integral comes from the fact that the Lagendre polynomials are only orthogonal and not orthonormal.
By normalizing the polynomials, we can follow HallsofIvy's reasoning.
2.
The integral I believe should be taken from -1 to 1, since the polynomials Pn are orthogonal on -1\leqx\leq1.
Having said that, the term that is multiplied by the integral would be <br /> \frac{2}{2n+1}<br />
rather than <br /> \frac{1}{2n+1}<br />.
What HallsofIvy has done is that he's taken the parity (even/odd) of the functions into account. Since for any function f, the product of f and Pn is even.
I'm still working on 3. Hope this helps.
Actually I think the terms
\frac{1}{2n+1}
and
\frac{2}{2n+1}
should in fact be
\frac{2n+1}{1}
and
\frac{2n+1}{2}
respectively.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
I'm interested to know whether the equation $$1 = 2 - \frac{1}{2 - \frac{1}{2 - \cdots}}$$ is true or not. It can be shown easily that if the continued fraction converges, it cannot converge to anything else than 1. It seems that if the continued fraction converges, the convergence is very slow. The apparent slowness of the convergence makes it difficult to estimate the presence of true convergence numerically. At the moment I don't know whether this converges or not.
