Dedekind cut problem in rudin; Problem 20, Chapter 1, Rudin
  • Context: Graduate
  • Thread starter Thread starter saim_
    Cut
3 replies · 5K views
saim_
I need help with the last part of Problem 20, Chapter 1 of Rudin. Here's the problem:
"With reference to the Appendix, suppose that property (III) were omitted from the definition of a cut. Keep the same definitions of order and addition. Show that the resulting ordered set has the least-upper-bound property, that addition satisfies axioms (A1) to (A4) (with a slightly different zero-element!) but that (A5) fails."
I'm just having trouble proving why A5 would fail without property (III).
Note: The appendix, referred to here, contains construction of reals using Dedekind cuts; property (III) is the requirement that a cut have no largest number; properties A1 to A4 are field axioms of closure, associativity, commutativity and existence of identify for addition. A5 is the property of existence of an additive inverse.
micromass said:
Hi saim! :smile:
Let [itex]\mathbb{Q}^-[/itex] be the set of all negative rationals (excluding zero). You've probably found out that [itex]\mathbb{Q}^-\cup\{0\}[/itex] is the identity for addition. Maybe you can show that [itex]\mathbb{Q}^-[/itex] does not have an additive inverse...
here is my attempt at a proof :-
let us assume that [itex]\mathbb{Q}^-[/itex] has an additive inverse. Let us call it β.
Then [itex]\mathbb{Q}^-[/itex] + β = [itex]\mathbb{Q}^-\cup\{0\}[/itex]
Then there is a p [itex]\in[/itex] [itex]\mathbb{Q}^-[/itex] and a q [itex]\in[/itex] β such that
p + q = 0. (since 0 is an element of [itex]\mathbb{Q}^-\cup\{0\}[/itex]).
But p is negative , thus q has to be positive.
Now , there exists a rational q1 such that 0<q1<q .
Further , [itex]\mathbb{Q}^-[/itex] contains the rational -q1.
By definition of addition ,the set [itex]\mathbb{Q}^-[/itex] + β
must contain an element
s = (-q1) + q.
But s is positive. Thus the set [itex]\mathbb{Q}^-[/itex] + β also has some positive rationals as it's elements, and is hence not the additive identity.
Thus there doesn't exist an additive inverse for [itex]\mathbb{Q}^-[/itex] .
*I wanted to know if this is a valid/proper way of proving what was asked in Rudin. I am new to analysis so wanted to better my proving skills. Sorry for posting in an old thread, but what I wanted to ask was being discussed here. Plus I was struck at precisely the point at which the hint is provided by the PF member - micromass.*
