Defining rho in spherical coordinates for strange shapes?
The problem involves finding a triple integral in spherical coordinates to represent the volume of a shell defined by two spheres: one with a radius of 2 centered at the origin and another with a radius of 1 centered at (0,0,1), specifically in the first octant. The challenge lies in defining the bounds for the radial distance ρ due to the overlapping nature of the two spheres.
  • Exploratory, Assumption checking
  • Participants discuss the bounds for φ and θ, which are established as 0 to π/2. There is confusion regarding how to define ρ, particularly when the angle φ is between 0 and approximately 26°, as it complicates the radial distance from the origin to the outer surface of the shell.
  • Some participants suggest visualizing the problem through sketches or projections to better understand the relationship between the spheres and the integration bounds.
  • Questions arise about how ρ can be defined when it appears to require multiple bounds, leading to discussions about the dependence of ρ on the angles φ and θ.
The discussion is ongoing, with participants exploring different interpretations of how to set the bounds for ρ. Some guidance has been offered regarding the need to express ρ in terms of the angles, but there is no explicit consensus on the correct approach yet. Participants are actively engaging with the problem and providing insights into the complexities involved.
There is a noted difficulty in defining a single radial distance ρ due to the geometry of the spheres, which leads to confusion about integrating over the shell volume. Participants are also reminded to use radians for angle measurements and to clarify the conventions used for the angles in spherical coordinates.
Stirling Carter
The problem asks for a single triple integral (the integrand may be a sum but there must be a single definition for the bounds of the integral) representing the volume (in the first octant) of the shell defined by a sphere of radius 2 centered around the origin and a sphere of radius 1 centered around (0,0,1) in spherical coordinates. dV must be in the order dρdφdθ.
For the large sphere, 4 = x^2 + y^2 + z^2, and for the smaller one 1 = x^2 + y^2 + (z+1)^2.
I know the bounds for φ, which are 0 to π/2.
The bounds for θ are the also 0 to π/2.
The integrating factor is ρ^2sinφ, for dV dρdφdθ.
What I don't understand is how to define ρ. What is particularly confusing is that when 0 ≤ φ ≤ ≈ 26° there is no single radius that extends from the origin to the edge of the shell. You can't draw a straight line from origin to outer surface without going through the smaller sphere.
Surprisingly, I was unable to find a similar problem posted here or anywhere else. If you know of one, I would greatly appreciate that link. Thank you very much for any input you have to offer.
Using ##\rho## for radial distance?
The outer bound depends on the outer sphere so you are fine there ... the inner bound depends on the angles, work out what that dependence is.
It may help to draw a sketch - perhaps a projection to a particular plane. Also to consider the volume as a difference between two volumes.
[slightly annoying that this is easier in cylindrical coordinates]
Thanks for your reply. Drawing a projection onto the yz-plane did help me visualize the problem; what remains confusing is the bounds of ρ for 0 ≤ φ ≤ ≈ 26°. In these cases, is ρ considered to be the sum of the distance from the origin to the small sphere and the distance from the other side of the small sphere to the surface of the larger sphere? I don't understand how to integrate with respect to ρ when ρ is broken up in such a way.
You are adding up the small volumes that are part of the shell ... you can think of is at adding the volumes that arev in the big sphere, then subtracting the volumes inside the little one... or adding the ones from the little sphere to the big one.
Check terminology: in spherical coordinates, it is usual for ##\theta## to indicate the angle from the z axis.
https://en.wikipedia.org/wiki/Spherical_coordinate_system
BTW: best practise - do all angles in radians.
I do understand the concept of an integral, I just don't understand how you can adequately describe what seems to need 4 bounds with 2 bounds. For example, at ρ extends from 0 to the lower edge of the small sphere. Then, ρ extends from the upper edge of the small sphere to 2. Here, I cannot say ρ goes from 0 to 2. I cannot say that it goes from the small sphere to the large sphere either, because a one segment would be left out. This is the source of my confusion.
Thanks again for your time.
Stirling Carter said:
I do understand the concept of an integral.
That is a problem - the integral is a summation. Revise.
For your problem - you have $$\int_0^{\pi/2 } \int_0^{\pi/2 } \int_{a(\theta ,\phi)}^{b(\theta ,\phi)} r^2\sin\theta \; dr d\theta d\phi$$ ... you are looking for hoe r depends on the angles. You actually have enough information to figure that out.
Thanks for the note about the convention of what θ indicates. I'll keep that in mind in the future but I'll stick with what I've been doing right now for the sake of consistency.
I tried to define the smaller sphere in terms of ρ, φ, and θ:
x^2 + y^2 + (z+1)^2 = 1
x^2 + y^2 + z^2 + 2z + 1 = 1
x^2 + y^2 + z^2 + 2z = 0
ρ + 2z = 0
ρ + 2ρcosφ = 0
ρ(1 + 2cosφ) = 0
ρ = 0
Is this inconclusive because for the same φ and θ there are two different ρ's ?
OK - so you are using ##\theta## for the angle from the x-axis and ##\phi## for the angle from the z axis?
(This is what I used to do - for consistency with cylindrical coords.)
For a fixed ##\phi## how does ##\rho##, for a point on the surface of the small sphere, vary with ##\theta## ?
(What is special about ##26^\circ##?)
Wouldn't ρ be the same for every fixed φ regardless of θ?
Well done ... so you just need to know how ##\rho## varies with ##\phi## ... so what is the polar equation of a circle that is not centered at the origin?
That would be r = (cosθ-π/2).
So I guess you could say that ρ is equal to (sinφ-π/2)
So the integral would be as follows:
∫0→π/2 ∫0→π/2 ∫sinθ-π/2→π/2 f(ρ,φ,θ) ρ^2 sinφ dρdφdθ ?
... well, check: when ##\theta = 0##, ##\cos\theta -\pi/2 = 1-\pi/2## but the actual circle needs to be 2 or 0... same for when ##\theta = \pi/2##... I'd start from the top and work down, say ##r=2\cos\theta## (check) so when ##\theta = \frac{\pi}{2}##, ##r=0##.
Urge you to learn LaTeX.
Thanks for all of your help! I will learn LaTeX before posting here again.
No worries.
There is a PF LaTeX tutorial around here someplace; you only need the maths part.
The surface ##x^2+y^2+(z+1)^2 = 1## is a sphere centered at (0,0 -1).
If the smaller sphere is centered at (0,0,1), shouldn't its equation be x2 + y2 + (z - 1)2 = 1 ?
10K
